-   -   Shift linkage setup (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1114383-shift-linkage-setup.html)
CO930 03-09-2022 06:44 PM
Shift linkage setup
I got the engine and transmission back in my 78 930, the clutch pedal cable connected and need setup the shift linkage. The manual states “turn the selector rod left in idle to stop”. Does that mean turn the shaft left until it stops? Is that neutral?
http://forums.pelicanparts.com/uploa...1646880211.jpg
356911930 03-10-2022 10:08 AM
Yes I believe so
Rahl
Matt at Pelican Parts 03-11-2022 06:24 AM
There's an article on adjusting and improving the shifter linkage for the 915 transaxle. If they share similarities it might be of some help to this situation
Shifting Improvements
Best of luck!
-Matt
gsxrken 03-11-2022 11:59 AM
Originally Posted by CO930 (Post 11631218)
. The manual states “turn the selector rod left in idle to stop”. Does that mean turn the shaft left until it stops? Is that neutral? ]
No, neutral will be found between the 1-2 and 3-4 planes. If you push the transmission shaft all the way back to the rear of the car, you’ll feel it thunk into a gear (that’s either 1 or 3), and if you pull it forward all the way that’ll be 2 or 4. Halfway between rearmost and frontmost positions, you’ll clearly feel it disengage… and that’s neutral. That’s the starting point for the twisting procedure in the manual.
CO930 03-11-2022 05:32 PM
Thank you. This is what I was looking for.
CO930 03-11-2022 08:45 PM
Is the shift coupler set screw something I can pickup at the parts/hardware store ?http://forums.pelicanparts.com/uploa...1647060323.jpg
pkabush 03-12-2022 11:53 AM
Not so much afaik. You could however buy the appropriate size grub screw and grind it to shape on a bench grinder.
Alan L 03-12-2022 12:36 PM
It is a tapered screw. Ideally you would get the proper screw. At a pinch, for temporary fix - as pkabush says. But it is a precision fit and important to hold its place for linkages to work. So, long term, proper screw will be needed. Even that one comes loose from time to time. (Loctite when you have proper screw and alignment right).
