-   -   930 differential output shaft - special length required (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1119271-930-differential-output-shaft-special-length-required.html)
Racer68 05-20-2022 09:26 PM
Hi all,
I'm in the final design stage of designing a Hayabusa powered open wheel hill climb (bitumen) car with a 930 LSD to take the torque.
My question is "who makes special parts" like a 55 mm extended length stub shaft" ?
Here is a pic of my proposal to show the layout.
Cheers
Johnhttp://forums.pelicanparts.com/uploa...1653107096.JPG
http://forums.pelicanparts.com/uploa...1653107113.JPG
908/930 05-21-2022 08:42 AM
A machine shop that specializes in gears should be set up to make splined shafts, some other general shops will possibly have the tooling.
Bucketlist 05-22-2022 04:14 AM
Well above my pay grade but look for Matt Monson he could have a clue.
Matt Monson 05-22-2022 06:17 AM
Why not just make a spacer to run between the flange and the CV, and run longer bolts? Why does it need to be at the gearbox side?
TurboKraft 05-23-2022 02:07 PM
California Motorsports dot net
