Mike80911's Avatar
Anyone know what this connector is for?
89 930 Cab Black
11 Cayenne
Old 01-14-2023, 04:00 PM
6 pin cdi box
it's not leaking....it's just marking it's territory
Old 01-14-2023, 06:26 PM
Mike80911's Avatar
Thanks. Should it be connected? I just found it laying there. Just bought the car and started to look it over
89 930 Cab Black
11 Cayenne
Old 01-15-2023, 04:25 AM
Jeff Alton's Avatar
Do you have a CDI box? Is car currently running? Do you, likely, have an aftermarket ignition system?
Cheers
www.turn3autosport.com
Old 01-18-2023, 07:03 PM
Alan L's Avatar
Yeah - it won't go if you are running on a CDI box. It is not far from the plug - just in front of the black plastic cover hiding some fuses and relays. Aluminium casting thing with fins on. If the car is going, it is redundant . It plugs in underneath the CDI unit - tight fit.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 01-18-2023, 08:26 PM
Mike80911's Avatar
The car is running and I don't see the box there I also do not see an aftermarket system, I guess I will have to take a closer look maybe the PO mounted a different system somewhere else.
89 930 Cab Black
11 Cayenne
Old 01-19-2023, 03:42 AM
It looks like the plug for the rear window defroster relay which you probably do not have with a Cab.
Old 01-19-2023, 11:08 AM
Mike80911's Avatar
That would make sense as you are correct as to no defroster.
89 930 Cab Black
11 Cayenne
Old 01-19-2023, 11:38 AM
Bucketlist's Avatar
Has the car had some serious work done to it by a po?
I have a couple of 8 pin CDI boxes mounted under the drivers seat that came with my Twinplug Turbo conversion.
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 01-20-2023, 02:17 AM
Mike80911's Avatar
Thanks for the replies. The car is at the detailer right now. When it was delivered the truck blew a hydraulic hose on the lift gate and covered the car in oil. Needless to say I was not very happy when the car was unloaded. But they are making it right, paying for a full detail and said anything else they can do to make it right they will be happy to help. When I get the car back I will take a close look at everything mentioned and try to figure out what exactly is going co with the CDI box and post some pictures of the area where it belongs.
89 930 Cab Black
11 Cayenne
Old 01-20-2023, 04:37 AM
