Drive it like u stole it.
Long overdue build thread
So this is a long overdue build thread that I really should have started back in 2003. My project has been delayed over the years by general life hurdles. Kids, house restoration, and a few moves. I took at least 10 years off at one point. I am sure lots of information about what's been done so far is lost. I figured I would at least start to capture some of the things I am currently working on in one place and maybe glean some guidance and knowledge from the comments along the way.
Here is my current project. I am modifying a Holley 75mm Throttle Body typically used on a 5.0 Ford to adapt it to the 3.2 EFI manifold along with adding an. adapter to connect it to my intercooler with a Wiggins clamp. Here is a video of the before and after of milling the top of the TB. https://youtu.be/NhCMM5vhj6k
____________________________ Bill Jones Jupiter, FL 77 Euro 911 3.0 Wide Body - under construction http://www.flickr.com/photos/rennsport/collections/72157618856489537/ |
Fear No Rust
Really interesting machining project.
Tell us more about your project, what year is it come post some pictures, etc. John |
1977 911 Carrera 3.0 Coupe At some point it received lots of parts from a 1976 930 that was wrecked. Most notably it has the engine (and sheet metal), a 930/50 3.0 Turbo motor that some have said is one of the first five hundred for that year. I purchased this car back in 1989 and drove it daily until around 1998. ![]() ![]() It was showing some rust, so I began to address that and basically opened up a can of worms. The car spent a few years in a body shop and was restored between jobs (and stored inside most importantly) at an incredible price by a very reputable local shop. At the time I was in an apartment, so it was nice that it had a safe dry home over this time. Picture from its final days in the body shop ![]() Fast forward till 2002, and she came home with a restored shell, but the time in the shop took its toll on the motor. ![]() After a few weeks of tinkering to get it running correctly, I finally achieved full boost (took a new set of injectors) and things went bad as she broke twelve head studs during a test run near my house. The studs corroded during its down time, so once they were really stressed, they failed. It was a cascading failure as they started to go. My wife went shopping and when she came home she took this picture of me. ![]()
[QUOT. My wife went shopping and when she came home she took this picture of me.
![]() If you were able to accomplish all of that alone while your wife was out shopping you'll have no trouble getting things fully sorted. Good luck - lovely color! |
Very cool project, I can’t wait to see more.
Fear No Rust
Bill,
Sorry to hear about the engine issues! Hopefully some top end work is all that is needed to get it running again. How far are you going to tear it down? I love the color and overall look of the car. John
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1105122-driver-survivor-black-1987-930-build.html Real IMSA 914 restoration: http://www.914world.com/bbs2/index.php?showtopic=91937 Basket Case 914 restoration: http://www.914world.com/bbs2/index.php?showtopic=79106 |
I'm pretty far along. Since this thread should have been started 20 years ago, I've got a bit accomplished between life's obstacles lol. Here are some disassembly pictures for you. ![]() ![]() ![]() The case, heads, and crank all went to Ollies. This included boat tailing, shuffle pining the case, knife edged the crank, and reconditioning the heads with the addition of twin plugs and port matched to the 3.2 EFI intake. I also replaced the Oil pump with a 964 Turbo pump and stock rods were replaced with Carrillos. I sourced a new 3.2 P&C set to up the displacement so it's now a short stroke 3.2L and a pair of GT2 EVO cams. Some reassembly pics. ![]() ![]() ![]() ![]() ![]() ![]()
Fear No Rust
Wow, what a sweet engine that will be (or is? seeing how you are catching up now).
I went with Carillo rods too and we found we had to clearance the oil pump a little with my 3.3 block even though Carillo did not specify that. John
7.0:1 > 11.3:1 > 7.0:1
Turbo'd short stroke 3.2, sounds interesting. What appropriate cr do think it will be?
If I recall correctly, it should be 7.5 up from the original 6.5.
Nice build.
A little more progress.
I completed machining the throttle body by adding the wiggins flange (still need to Tig it on) as well as mounting holes that match the intake. This eliminates the need for an adapter plate and gains about 1/4" of clearance and one gasket. I used the O.E. cap screws but had to make custom 6mm washers with a 10mm OD to fit in the counterbore. I used some bronze bearing stock I had for these. I picked up a small mini-lathe and have ben modifying/improving it over the last few weeks. It's a handy tool for the shop for sure! I have already used it to make parts for the car as well as the house lol. My next challenge is making a custom gasket for the TB. I have a Cricut as well as a laser engraver/cutter in the shop. I still need to determine the best material to make it out of. I tried to contact Fel-Pro but they have not responded. They have a lot of different materials available. Any suggestions are welcome! I won't be able to cut anything with metal in it but want to make sure it will hold under boost pressures. I originally thought of cutting an orange grove into the TB like the Porsche one used, but there is just not enough material left since the 70mm is so much larger than than the O.E. TB. ![]() ![]() ![]()
Q: why the larger throttle body?
Was the Carrera one missing?
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
The thought was that the OE TB (I do have it by the way) would not flow enough. I also wanted to incorporate the wiggins clamps that I have. Any advice/recomendation from you would certainly be welcome. I fear the 75mm TB will be a bit touchy just off idle. Here are some engine specifics: 3.2L Short Stroke GT2 Evo Cams 7.5CR Twin K16's (off of a 996) Brians Headers MODE Full Bay Intercooler Motec M600 ECU
OK, I can understand how you got to where you are today.
It’s the touchiness I was concerned with, what with your engine only being 3.2 L displacement. For whatever it is worth, Tom McElligott’s UBER930 was 3.45 L and a Carrera manifold, made 722 at the wheels on a Dynapack with a stock Carrera throttlebody and linkage. Much of that throttle linkage is now NLA from Porsche, so hopefully you have it. If not, hopefully you can borrow it and copy it. It has all the lengths and angles correct for good progressive throttle control. In lieu of all that I would normally suggest running a Bosch DBW throttlebody as it bolts directly to the Carrera manifold, only I don’t believe the M600 can control that? |
The M600 does have the option for DBW but it requires a license. With it now being obsolete I am unsure if I can even get it now.
Awesome build and subscribed.
It's crazy how the MANY years melt away when life, family, jobs and moving become the priority and the car stuff (no matter how important or valuable) takes a back seat. Kudos to getting back on track and looking forward to updates. Yasin
Ole Skool - wouldn't have it any other way |
Just as it says in my sig line.. ![]()
RGruppe #180 So many cars.. so little time!! |
You make an excellent point here, Bill. And welcome to the forum. The world has changed over the last 25 years and so have we, and our expectations. I recently rebuilt and renewed everything on my engine to OEM spec (except SC cams, 7006, and headers) for the sake of civility, or as you said, “reliability with modest HP”. If I wanted 600HP, I would ship it to Turbokraft for that power WITH the civility and OEM-mannerism he delivers. It’s those in-between home brew builds that can so often suck, where either the CIS is fat all over or the megasquirt EFI never got the dyno hours or know-how it really needed. I just don’t have the patience for that anymore… god bless those guys that do- they keep this board interesting.
Ken 1986 930 2016 R1200RS |
Nice project. If using a stock 3.2 throttle body, how do you connect your intercooling piping to it? Is there a well-known and common method?
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Thread Tools | |
Rate This Thread | |
