1987 turbo bracket question
Anyone know the dimensions of the little spacer in the picture below?
![]() Thanks, Will Sent from my iPhone using Tapatalk
1987 Marine Blue 930 1982 911SC White Plains, NY |
Work in Progress
Will,
I will try and check this for you tonight.
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 |
That would be huge Rich. Any info you can gather on overall dimensions would be quite helpful. Thanks!
Work in Progress
Sorry for the delay.
1. Outside Diameter: 18mm 2. Inside Diameter: 10mm 3. Height from back of bracket to the end of the spacer: 29.26mm ![]()
Work in Progress
You’re the man Rich!
