-   -   FS: Full Width Intercooler (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1138813-fs-full-width-intercooler.html)
TurboKraft 04-24-2023 03:15 PM
Cross-posting to the "Porsche 911 Used Parts For Sale & Wanted" forum, too
We have a lot of take-off parts from projects over the years, and only so much space… So it’s time to make space and let someone else get some use and value from these parts on their Porsche.
Full Width Intercooler for 1978-89 Turbo
Can be adapter to 1991-94 Turbo
Plenty of cooling core volume and surface area to support any CIS-injected engine
Has supported 600hp on EFI 911 Turbos (ex: MODE-built 3.3L)
Heavy duty cast aluminum inlet & outlet tanks.
Original manufacturer: Blown Six
Have fun reading through the archived stories if you're so inclined – sometimes these fit fine, other times they didn’t, but they did perform.
This was removed from a heavily modified 1986-88 930 engine, and at one point had 4x piggyback fuel injectors spraying into the intercooler’s outlet tank in order to try to provide adequate fueling and keep the engine from blowing up at very high boost pressures. (It didn’t work, RIP engine.)
Those holes have now been drilled out, TIG welded shut, and sanded smooth.
Everything else is as we removed it from the engine: outlet for a HKS (or equivalent) blow-off valve, some other port previously welded shut on the bottom of the inlet tank, etc.
Asking $850 + shipping
NOTE: this is a longneck intercooler, meaning it sits directly atop the throttle body.
No diverter valve or related parts are included.
1991-94 964 Turbo parts would be used, and they are inexpensive and readily available.
http://forums.pelicanparts.com/uploa...1682374198.JPG
http://forums.pelicanparts.com/uploa...1682374369.JPG
TurboKraft 04-24-2023 03:16 PM
http://forums.pelicanparts.com/uploa...1682374526.JPG
krasuskyp 04-25-2023 07:35 AM
screamin deal - someone should snatch that up right quik... yuuuuuge & impactful improvement to the car, and a decent enough piece
1Bad86 04-25-2023 09:11 PM
Man I want but the recently discovered cracked header on my garbage is cutting deep into my fun budget.
I still want to get the turbo Chris and I discussed last month.
I do dig the old school Andial that I'm running though and hate to take it off but there ain't nothing like a full bay IC chilling on top of of a flat 6.
I need to hurry up and list all my old take offs lol.
slow&rusty 04-26-2023 04:06 AM
Nice unit and price!
Blown Six..the good ole memories.
Would make a nice upgrade over the stock 930 IC.
gassian 04-26-2023 08:43 AM
if i did not have the nicely looking TK LongNeck Intercooler , i would have jumped on this in a heartbeat.
kamaro 04-30-2023 12:06 AM
I will take it, that will be the perfect add to my 3.3 EFI project. PM sent.
TurboKraft 05-01-2023 10:57 AM
SOLD
Thanks, kamaro!
