New custom made headers for the 78 930
I have been having problems with my headers and finally threw in the towel on them and had a friend make me some new ones doing away with the bad issues of the stock ones. All new from heads to turbo.http://forums.pelicanparts.com/uploa...1688412733.jpg
http://forums.pelicanparts.com/uploa...1688412733.jpg |
Wow, nice!
Wow indeed!
Thanks!
I switched it from a cable operated clutch to hydraulic operated one and the aftermarket mount for the slave cylinder that is commonly used puts the slave cylinder so low I drug it many times. If you look close, he made a much better slave cylinder mount for the clutch that brought it up much higher than it was before. |
You are lucky to have that friend. Absolutely beautiful!
Very cool! Beautiful fab work.
I think I need better friends! |
turbo headers
Hi what is the ID of the tubes you used and do you have stock port size on the heads..
What are you using for the clutch pedal? Modified stock assembly or did you retrofit a factory hydraulic pedal cluster? |
The engine was put together in 1986 by 'Andial' they did a lot of modification's, and there are a lot of aftermarket parts and non 930 stuff on it. I have no paperwork on what they did. I can see they drilled? the heads for a second plug and I was told there is a oil passage made for the exhaust guide. They might not even be 930 heads; the heads might have come that way from Porsche that way? I am not sure of the port size. I just do not know :confused: |
Yeah… we’re going to hear more about this friend. I see you’re in AZ. How close to 1716 W Broadway Road Unit #123 Mesa, Arizona 85202 does your friend work?;)
He is setting up jigs to make Porsche air cooled exhausts. |
The clutch pedal is just as hard depress, but it now can be released smoothly. |
Turbokraft has been making These for a couple of years havent they? Look supernice, but my wallet doesnt agree
| All times are GMT -8. The time now is 12:52 PM. |
