New custom made headers for the 78 930
I have been having problems with my headers and finally threw in the towel on them and had a friend make me some new ones doing away with the bad issues of the stock ones. All new from heads to turbo.
Old 07-03-2023, 12:33 PM
Fear No Rust
fourblades's Avatar
Wow, nice!
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1105122-driver-survivor-black-1987-930-build.html
Real IMSA 914 restoration: http://www.914world.com/bbs2/index.php?showtopic=91937
Basket Case 914 restoration: http://www.914world.com/bbs2/index.php?showtopic=79106
Old 07-03-2023, 03:22 PM
Grappler
Rodsrsr's Avatar
Wow indeed!
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 07-03-2023, 04:41 PM
Thanks!
I switched it from a cable operated clutch to hydraulic operated one and the aftermarket mount for the slave cylinder that is commonly used puts the slave cylinder so low I drug it many times. If you look close, he made a much better slave cylinder mount for the clutch that brought it up much higher than it was before.
Old 07-03-2023, 08:14 PM
You are lucky to have that friend. Absolutely beautiful!
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management.
-1987 Carrera Coupe.
-2013 Carrera S PDK Coupe, factory Aero Kit. My DD.
-1987 928S4.
Old 07-04-2023, 12:05 AM
Very cool! Beautiful fab work.
Old 07-04-2023, 04:01 AM
Agree
I think I need better friends!
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 07-04-2023, 02:06 PM
turbo headers
Hi what is the ID of the tubes you used and do you have stock port size on the heads..
Old 07-04-2023, 03:15 PM
Armed Bastard
djb25's Avatar
Originally Posted by ficke View Post
Thanks!
That’s a pretty cool hydraulic clutch setup.
What are you using for the clutch pedal? Modified stock assembly or did you retrofit a factory hydraulic pedal cluster?
Damion
'77 911S Turbo, EFI 2.7l, Carrera intake, Megasquirt 3 with MS3x, Fuel & Ignition
Old 07-09-2023, 05:31 AM
The ID of the primaries, coming right from the heads is 40MM/ 1.5 inches.
The engine was put together in 1986 by 'Andial' they did a lot of modification's, and there are a lot of aftermarket parts and non 930 stuff on it.
I have no paperwork on what they did. I can see they drilled? the heads for a second plug and I was told there is a oil passage made for the exhaust guide. They might not even be 930 heads; the heads might have come that way from Porsche that way?
I am not sure of the port size. I just do not know
Old 07-09-2023, 06:14 AM
Yeah… we’re going to hear more about this friend. I see you’re in AZ. How close to 1716 W Broadway Road Unit #123 Mesa, Arizona 85202 does your friend work?
Ken
1986 930 2016 R1200RS
Old 07-09-2023, 06:19 AM
Could not get closer
He is setting up jigs to make Porsche air cooled exhausts.
Old 07-09-2023, 06:21 AM
I used a stock Carrera unit from a G50 car, it was pretty straight forward as it bolted in, then I shoved the unflared hydraulic line through the clutch cable tube to the pedal assy. the hard part was standing on my head to flare the end of the tube, Luckly it worked first try and no leaks.
The clutch pedal is just as hard depress, but it now can be released smoothly.
Old 07-09-2023, 06:27 AM
Axel84's Avatar
Turbokraft has been making These for a couple of years havent they? Look supernice, but my wallet doesnt agree
Old 07-09-2023, 06:49 AM
