Banned
(2) exman studs needed - size
Anyone happen to have a pair of spares laying around? Had a pair exit the chat, getting annoying (likely due to my previous timecert effort years ago)
If not, what size are they - and - what is your suggested source?
Does the standard size come long enough to double-nut for install with header in-situ?
Alternatively - suggested ARP source for (2) not a whole kit of (12)? Pretty sure these have allen heads for easy install.
Any assistance appreciated!
Old 09-24-2024, 09:42 AM
Belmetric is your friend for anything metric. Check it out. Have used them for years. Use the copper coated flange locknuts and you don't have to double nut.
Old 09-25-2024, 06:14 AM
Banned
thanks boosted
anyone else on the sizes needed etc? No one got a pair 'o spares layin around?
Old 10-01-2024, 06:14 AM
Ollies930's Avatar
I will look in my garage tonight and get you the specs. Chances are, I have a couple of spares as I am going to use much thicker exhaust flanges than stock, so stock will probably not work. If I find they are too short, they are yours.
Old 10-01-2024, 01:27 PM
Ollies930's Avatar
What I found does not match the PET. According to the Porsche parts catalog the studs are supposed to be 35mm long. What I have is 50.1mm and 50.6mm long (maybe different supplier?). I am certain that these were in my heads on the exhaust side. If you want them. they are yours.
Old 10-01-2024, 08:58 PM
proffighter's Avatar
Those seems to be correct. DIN and newer norm alway tell the lenght without the part screwed-in. So in your case it's 35 (rather 34)mm stud D2 means 34 plus 2xDiameter 16 = 50mm
Roland
930 Turbo '81 Too many modifications to list
Old 10-02-2024, 02:40 AM
Banned
Thanks so much Ollie and Roland - that's very kind of you, I appreciate it.
Kenny here is driving me a pair next week - should they be shorter I'll take you up on it, as I'm wondering if they're going to be long enough to install with header in-situ to be able to double-nut them.
Any insight there is HELPFUL!
Old 10-02-2024, 10:54 AM
