964 turbo increasing boost....dyno tests.
Hello Guys, I will share with you reliable information about how the stock 964 Turbo reacts to increasing boost. The measurements were made on the Maha dynamometer and the measurement itself lasted about 20 seconds under heavy load, which is comparable to the conditions on the road of an accelerating car. The power measurements you do in America and which last 5 seconds are unreliable to me because they have nothing to do with real conditions and the load to which the car is subjected. Maybe it works for you because you simply don't drive at high speeds because you have nowhere to go, in Germany we drive these cars at 300 km/h and it takes a long time. Returning to the measurements, one measurement was made at 0.7 bar and the AFR at 6500 rpm is 12:50. The next measurement is 0.9 bar and above 5000rpm it is already lean. The next measurement is 0.98 bar and at 6000 revolutions the AFR is 13:50 which, as we know, is unacceptable. What's interesting is that this stock motor produces almost 580NM.
Despite air blowing onto the intercooler, with a higher boost the intercooler got very hot. Cooled cold water spray was also used for measurements thanks K |
Here is dyno run of my ex 997 turbo from 2011. Compare it with dyno runs made in America.
https://youtu.be/pWbHzQ0uw_A?si=jPkRTuchC7MKnHrz |
Either way enjoy it while you can, the way European cities are trending...even walking with flip-flops on will be banned soon. |
I’ve never been anywhere where I felt the need to accelerate WOT for 20 seconds. Regardless, your results are silly considering the AFRs you hit to accomplish them. Not really impressive.
In my car AFR is just fine considering boost im running http://forums.pelicanparts.com/uploa...1696077940.jpg
Going back to the topic rising boost to 0.9 bar is pointless in the stock car.
First, thank you for posting the data. It's always good to have some real-world info on how the cars perform with modifications.
Second, excuse us here in the States. We're just slightly jealous that you can drive around at 300 kph and we can't. |
That’s why you ditch the CIS and go EFI. Limited power and safety potential with CIS.
I will post soon dyno run of my car which runs only 0.85 bar boost from same maha dyno http://forums.pelicanparts.com/uploa...1696101041.jpg |
Running a long dyno run, as compared to a shorter one, helps mask things like heavy engine or driveline components. Additionally, the only time you spend that much time in one gear, is potentially in top gear. That means you are ignoring all the gears below top gear. There is a reason why most dyno acceleration rates are set where they are. On most engine dynos you can set the rate of acceleration to what you desire, within reason, but you will find that the power levels will show an increase on the slower acceleration rates as opposed to the faster ones. And for tuning you want to get as close as possible to what the engine will see most of the time.
If the engine does not generate any problems under such a heavy load in the highest gear, it means that there will be no problems in lower gears its simple.
Btw. All above cars measured on 4th gear. 997tt from the movie on 5th so non of this cars measured on highest gear |
I drive mine as fast as I fukkkin want - all day everyday all the time everywhere. 'Merca! SmileWavy And why keep it as stock as possible? Short sighted IMO 13.5afr?? Um yeah no. |
http://forums.pelicanparts.com/uploa...1696270847.jpg |
Coming back to the topic of increasing the boost in the 964 Turbo with original fuel systems, it simply does not make sense, and I have noticed that increasing the boost to 0.9 bar or even 1.0 bar is often the first choice.
