Convert 993 to 993 turbo
I am really liking the 993 Turbos but prices are high. So, I was thinking of buying a 95 wide C4 coupe and then having the motor turbo charged and possibly modify for more performance. Besides lower compression pistons, bolts, and the usual turbo stuff, would this be a difficult conversion? Anyone have a parts list?
Old 11-29-2023, 02:04 PM
Chain fence eating turbo
IMO, if you have fabrication skills and determination, it’s isn’t too difficult. Yes, there will be headaches along the way, but that’s par for the course. With todays turbo and intercooler efficiency, lowering compression may not be needed.
Old 11-30-2023, 10:53 AM
Ollies930's Avatar
Single turbo, twin turbo or a faithful replica of 993 Turbo?
Old 11-30-2023, 09:58 PM
I think the 993 twin turbo replica would be good and if there is a way to bump up the hp a bit to 500-550+ crank hp on pump gas without sacrificing drivability on street I think that would be perfect.
Old 11-30-2023, 11:02 PM
You can get 500-550HP without suffering drivability, easily.
1 bar of boost should net you that with no other things done.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 12-01-2023, 08:09 AM
Turbo'ing any engine is not that defficult; the hardest part propably be the wiring and the tune, as I would NEVER turbo any engine using stock wiring/ecu.
Old 12-01-2023, 08:39 AM
7.0:1 > 11.3:1 > 7.0:1
Been there. Even running 100% methanol I couldn’t get to 1bar. Pulled out timing until it fell on its face. CR, that’s where it’s at.
Old 12-01-2023, 07:36 PM
Mike Billings's Avatar
What's the stock static C/R? 11.5:1 I think!
07 911 Turbo - Pilot Sport Cup 2 ZP
96 Carrera 4 - Toyo R888r
73 911E - Hoosier R7 + twin 75's
92 Corvette - Nitto NT01
14 BMW X3 - Pilot Sport A/S 4
Old 12-02-2023, 05:39 AM
Static is published at 11.3 for both 993 and the 964 as well.
Old 12-02-2023, 08:22 AM
Steve Weimer stated 10.6-10.8:1 actually.
Overstated apparently.
Old 12-02-2023, 06:56 PM
Ollies930's Avatar
Easy solution, swap in 993 Turbo pistons, 8-1 compression. And putting in a longer duration camshaft will also help bleed off a bit of cylinder pressure to make things survive at higher boost levels.
Old 12-03-2023, 09:05 AM
TurboKraft's Avatar
+1
Start with 8:1 pistons, and standalone engine management.
There were no factory widebody non-turbo cars in 1995.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 12-04-2023, 09:45 AM
speednme1's Avatar
Widebody of the 993 didn’t come out until 97 in the form of C2S or C4S. A nice one of either will run you $135-60k…add another $50k+ for engine and possibly transmission work and you’re at 993 Turbo money.
Rey....77 930 "the Mistress"
Old 12-04-2023, 10:09 AM
Administrator
Matt at Pelican Parts's Avatar
There's a thread here from a few years back with a pretty decent build sheet. Perhaps it might help with the brainstorming process:
https://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1010267-964-993-turbo-build.html
Old 12-04-2023, 02:15 PM
Thanks for the info guys. Looks like more to research before going with this as option.
One more question, besides the turbo engine and rear spoiler, are there other significant differences between the turbo and 98 wide body?
Old 12-05-2023, 07:56 PM
