Lost Tune: Does This Ignition Table Look Reasonable?
I did something dumb and somehow reverted to an old tune, version unknown.
1986 930 stock internals except SC cams. Single plugged with COPs, running 1 bar of boost.
Does this ignition table look correct and reasonable?
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 12-20-2023, 09:55 AM
Ignition Table
The table is similar to my current tune. I have a much deeper hole at 1200 RPM to control idle but the timing on boost and cruise is very similar.
Regards,
Lee
Old 12-23-2023, 02:39 PM
umop apisdn
Just a thought,
have you checked your restore points in Tuner Studio, just in case it saved the tune when it connected the first time?
Automatic Restore Points - TunerStudio automatically saves all your settings on key events or changes to the Controller Configuration so you can restore all or part of your settings and tune from a previous point in time. You can also view a graphical different report of any changes between he current settings and the restore point. Some of the default key event:
Project close - if there have been any changes to your tune or settings a new restore point is automatically saved.
Accepting Controller settings during a difference report on connect.
Loading a previous restore point or msq.
1981 928S 4.7 ROW with KE3-Jetronic
"Be the man your dog thinks you are."
www.FrankenCIS.com
Old 12-24-2023, 05:33 PM
