1987 911 turbo battery size? what is best?
looking for some direction.. i have a 1987 911 turbo, there is 2 battery sizes you can use.. what do you Porsche people recommend? there is a H8 (49) and weighs just over 55lbs and it is a super tight fit, but fits... and there is a H6 (48) that is just over 45lbs and is a lot easier fit.. one last question, would you use a dry battery or a wet battery? thanks for all you help in advance... K
I have been using the smaller 51R, available at Costco, for several years with no problems.
I have been using the smaller battery size. It is plenty - as long as you don't have starting issues.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
I got about 7 years of use out of my PC680. The car started very easily, and I shut the battery off with a kill switch after every drive, so that may have contributed to the long life. I also never put it on a trickle charger.
Garen GNdesignLLC.com - Automotive Art & Sculpture |
thank you, for all your input... k
I have yet to understand why the God's at Porsche felt we would need a mondo huge tractor battery, unless maybe it was for those nights in the mother country where it was colder than a witches tit and needed the CCA to crank through frozen oil sludge. Mine died over a year ago and I happened to have a standard 12v battery on hand for almost any application. Works fine other than having to fabricate hold down straps.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
In the past I used the PC680 Odyssey, but their prices have sky-rocketed, so now use the ETX20L battery which is dimensionally identical incl. weight but available at a much cheaper price from nearly all auto stores.
I modified the Odyssey aluminum battery holder to fit the ETX20 and always keep it on a tender. As it is an AGM battery it hates voltage swings and if they drop too low, it will drastically reduce their life. A $25 tender from Amazon goes a long way.
Ole Skool - wouldn't have it any other way |
I'm old so I will have to go and look in my car, but, 90% sure the new Odyssey R37 has the posts on the correct end and on towards the center of the car. I have a plate it bolts down on so that the factory battery securing points work. I got almost 8 years out of my last one. Battery tender is a must.
Chris 89 930, 87 930, 86 930 Ruf BTR tribute, 89 Ruf CTR tribute |
I've had good luck with Optima so I just replaced my 6 year old ~40 lb 34/78 with a 34 lb 75/25 battery. They don't have hold down tabs on the bottom so I bolted an aluminum tray on the bottom the same dimension as the stock battery.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
^^^ that's what I just replaced, Optima, not Odyssey.
E-85 sippin drunk
I run a Oddesey PC925 in my smugglers box. I usually have to replace it around the 4 year mark. It's lightweight, and has plenty of power to start our 930's. and it gets that weight away from that outer corner, and more centrally located in the car.
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
1991 C2 Turbo
all electric everything I have been using for years with zero issues: a small AGM - 189 $ https://www.batteriesplus.com/battery/car-and-truck/mazda/miata/1999/base/l4-1.8l Porsche 930 and 964 Turbo's are low compression Stefan |
Chain fence eating turbo
I have 7.5:1 CR and a gear reduction starter. I’m pretty sure a lawnmower battery would be enough CCAs to start mine
