Brando
quattrorunner's Avatar
oil
Sooooo
it's been a few years since I've changed my oil. What's the good stuff these days?
Turbo powa!
1977 911s. it's cool
Old 05-17-2024, 09:40 AM
David's Avatar
I'm partial to Brad Penn 20W-50 for my 930 (Mobil 1 on all the modern cars)
Old 05-17-2024, 10:33 AM
Brando
I used to use v-twin mobile 1
Turbo powa!
Old 05-17-2024, 11:08 AM
Driver
Noah930's Avatar
I use the 5-quart jugs of Mobil 1 15w-50. Easy and cheap to buy from Walmart online. My mechanic (indy shop) uses Brad Penn. Mobil 1 V-twin is also good, as well as Driven, Royal Purple, VR-1, and a couple others.
Old 05-17-2024, 06:11 PM
Bucketlist's Avatar
Originally Posted by quattrorunner View Post
Sooooo
I love it.......someone that will admit not changing their oil at least yearly regardless of mileage. I'm a believer that with the current quality of oil, as few miles I may log over a period of time and with a clean (indoor) storage environment, an engine that is clean enough inside that the oil can look new when you drain it, an oil change every 2 or 3 years is not out of the question.
I keep these on hand for when I feel a change is necessary:
Mobil 1- 15w50 10 qts bought at Walmart in 5 qt jugs
Mahle 0C54 oil filter purchased online.
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 05-18-2024, 03:50 AM
Alan L's Avatar
I am the same with my SC - I don't go draining 'fresh' oil that has a few kms on it and been sitting for a year. But I think the key is to get the engine to working temp for at least a modest duration (not just warming it in the shed). Blow the condensation out. I suspect the condensation is as big an issue as anything.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 05-18-2024, 01:49 PM
Driver
Noah930's Avatar
I change annually, as I put on at least a 2-4 thousand miles per year. I don't know if the detergents and such in the oil "wear out" with time, but there are acids that build up as a by product of combustion, so I'd rather not have that etching away at metal stuff. Gives me an excuse to feel manly and use some tools for an hour, at the very least.
Old 05-18-2024, 02:03 PM
Brando
My engine only had about 500 miles max.
Turbo powa!
Old 05-18-2024, 02:07 PM
Ollies930's Avatar
I used to think that the Mobil1 V-twin oil with its higher ZDDP content would be superior to the others, but I am starting to wonder if that is necessarily true. Two potential problems, 1) there is an additive package designed for wet clutch pack and 2) the higher the ZDDP content, the lower the detergent content. Potentially the 15W-50 should prove adequate, but if you want to add a higher ZDDP content, you could always add a quart or two of 0W-50 racing oil. But then again I am purely guessing here with what little tribology knowledge I possess. And just to confuse things a bit, I added the description for the more interesting Mobil1 oils.
Old 05-20-2024, 09:50 AM
Banned
Hey Brando! Great to hear from ya here again, been awhile. Damn, 500mi is uber light for you! Hope all's swell?
Sooooooo, I was a Brad Pitt - errr - PENN user for years, then more recently Valvoline VR1.
TK put in Driven DT50 with my rebuild and I've changed it w/ that a couplefew x's since.
DOOOOD. I'll say... that shiiit is daBOMB!!! It's BONKERZ CRAAAAZZZY STICKY!!! It's the gooiest stickiest stuff I've ever experienced - by ALOT.
If it's good nuff fer da MAESTRO it's good nuff for me!!
Give it a look!
Old 05-20-2024, 11:06 AM
Brando
Give it a look!
Doing well indeed.
I have moved home and business. The car took a backseat.
However 500 miles would still be pretty light. Let me explain,
I was still in the tuning process. One day I swapped my rear stickies for some more mellow 225section tires because of the leak I had in the rear tire. Well I found those pretty entertaining and one night on my way home from work I thought maybe I’d try a 2nd gear drift which I’d never done. Well it was a spin and stuff into a curb that took the car off the road. It was an easy fix but I decided I wanted to do a backdate which I didn’t expect to take too long but it’s been 7 years. I’m nearly ready to drive again.
Turbo powa!
Old 05-20-2024, 01:16 PM
Bland
unclebilly's Avatar
I have been using Brad Penn / Penn Grade in my air cooled Porsches since forever.
The turbo on my 86 930 was leaking oil and used 5 or 6 quarts on the way to Luft last year. I didn’t have enough Penn Grade with me so I switched to VR1 20:50 - it’s all I could get on the road. The turbo quit leaking and the car used less than a quart on the return trip.
I called my turbo builder and he said that he hates getting a turbo in for rebuild that has been running the Penn Grade oil - they are all coked up. He told me that 1 qt of consumption was totally normal in the 2100 km return trip. Yay! I didn’t need to rebuild my turbo…
So yah - VR1 all the way now.
Old 05-20-2024, 05:49 PM
Jeff NJ's Avatar
I will say I agree with the Brad Penn comments Brad Penn is fine for NA air cooled Porsche's, but add in a turbo and the heat can break down any conventional dino oil and coke up the oil passages. That's why we should be using synthetic oil. Much higher resistance to breaking down due to heat and no coking at all.
I use 20/50 VR1 full synthetic or the mobil 1 V twin.
Be careful, because there is a VR1 conventional, that will have the same coking concerns. Worse, it says right on the bottle that it's not for prolonged use with catalytic converters (if anyone still has theirs on). It doesn't say that in the synthetic version.
1988 930 Venetian Blue
Old 05-21-2024, 05:03 PM
Amsoil 20/50 every 5k for the last 125K (ish) miles. Usually Premium or Z-Rod, both with high Zinc. Just rolled over to 159,000 this week on a trip.
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 05-22-2024, 02:27 PM
bleachii's Avatar
Wow. Very interesting. I have Brad Pitt in my garage. He was in the 930 and I had a bunch of leaks. Recently as many may know from my thread I had turbo seal issues and photos proved a super coked up turbo. Of course the car is old and not driven enough so can’t say Mr Pitt was an issue but interesting now that I hear others experiences and thoughts. My current mechanic said VR1 so that’s what I’m running. New turbo. Still a couple leaks but I’m hoping they are self healing as I put miles in her. Kraus, you’re a crack up.
Old 05-22-2024, 07:25 PM
