Happiest when Tinkering
gsmith660's Avatar
megasuirt friends help please
Trying to figure out how to post my msq and logs any help would be appreciated
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 08-23-2025, 08:07 AM
Are you asking how to post your msq?
1. Open Tuner studio.
2. Open your project.
3. Click on File, then click on "save tune as"
4. Pay attention to where you are saving the file.
5. Upload.
** If you are using Windoze. It is usually under documents/TunerStudioProjecs/** what ever you names your project**
Old 08-23-2025, 09:24 PM
gsmith660's Avatar
Actually I need eyes on my msq and there is no way to upload to the forum
Old 08-24-2025, 03:44 AM
It's a 914 ...
stownsen914's Avatar
You should be able to. See highlighted button below ...
Old 08-24-2025, 10:28 AM
Fear No Rust
fourblades's Avatar
If you post screenshots of your various tables (afr, advance, ve, etc.) you might get comments from people who know tuning but don't have tunerstudio/msquirt.
John
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1105122-driver-survivor-black-1987-930-build.html
Real IMSA 914 restoration: http://www.914world.com/bbs2/index.php?showtopic=91937
Basket Case 914 restoration: http://www.914world.com/bbs2/index.php?showtopic=79106
Old 08-27-2025, 05:31 PM
gsmith660's Avatar
John
That is an excellent idea I will get some screen shots tomorrow
Old 08-27-2025, 05:44 PM
gsmith660's Avatar
Here is the VE and spark tables
Old 08-28-2025, 06:59 AM
gsmith660's Avatar
Let me know what else you would like and I will screensot that as well
Old 08-28-2025, 07:05 AM
gsmith660's Avatar
The main issue I have right now is when I let off the throttle the car dies I have been trying different settings but havent made any progress
Old 08-28-2025, 07:26 AM
How were you able to setup load as PSI?
Mine is currently kPa.
Old 08-28-2025, 03:25 PM
gsmith660's Avatar
I dont know it did it on ots own
Old 08-28-2025, 04:51 PM
Found it under Options - Preferred Unis.
Old 08-28-2025, 05:24 PM
do you have fuel cut on overrun turned on or off?
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 08-29-2025, 08:50 AM
gsmith660's Avatar
not right now do I need to?
Old 08-29-2025, 09:15 AM
My 2 cents.
Based on the other posts the engine runs and idles.
I have not used VE to tune before, but the VE table drops to near zero at higher vacuum numbers this could be drying up the intake and causing a stall going back to idle with the throttle closed. I had to finesse my tuning in this area to "catch" or return to idle gracefully after a higher RPM letoff.
The ignition numbers look reasonable for twin plug at operating RPM. I would have expected closer to TDC at idle, but this wouldn't stall the engine.
Hope this helps.
Lee
1982 Porsche 930 - 3.4L, Motec M84 EFI, BB headers + intercooler, Ruf muffler, K27.2, Turbosmart BOV
Old 08-29-2025, 09:45 AM
Chain fence eating turbo
Whoa……PSI. I’m accustomed to kPa.
Very hard to understand what the motor is doing in vacuum for me reading PSI.
First time I prefer metric over imperial
Old 08-29-2025, 11:52 AM
gsmith660's Avatar
I will sgreenshot again with proper units
Old 08-29-2025, 04:46 PM
gsmith660's Avatar
Ok here they are with proper units and they are the latest map from todays drive
Old 08-30-2025, 12:59 PM
Could be fuel overrun too as suggested. I adjusted my settings a few times to get the balance right. Any datalogging capability for AFR?
Lee
Old 08-31-2025, 07:26 AM
gsmith660's Avatar
i did disable the fuel over run and it helped alot but still will die when I let off the throttle from higher rpm
Old 08-31-2025, 07:44 AM
