| Registered Join Date: Mar 2011
				Titanium Turbo Blankets & Exhaust Wrap?
			Hey guys, What are your thoughts on using turbo blankets to keep heat away from engine components? With my TT setup, the turbos are very close to the bottom plug leads, so I’m thinking of using these titanium blankets to keep heat inside the turbo hot housing rather than dissipate to nearby engine components. Note: The car is pure street, not track focused. Thoughts?  Also looking at wrapping the exhaust between the turbo and muffler with this exhaust wrap. Would also protect the oil drain lines, especially from the hot housings which glow red!   Last edited by 911TT33; 11-21-2024 at 06:10 PM.. | ||
|  11-21-2024, 06:07 PM |
| Ingenieur |
			Generally, we instrumented the bearing housing at the turbo drain side. If it went over 135 C you were in trouble. That meant having to use a water cooled bearing housing. Not really an easy option for us. I think you would be over 135 with a turbo housing blanket. They make fiberfrack sleeves for spark plug wires. Have you considered that?
|  11-22-2024, 07:36 AM |
				 | Quote:
|  11-22-2024, 10:32 AM |
| Registered |
			Would not recommend wrapping any exhaust piping between the turbo and muffler with header wrap, it locks the heat in, over heats the exhaust head pipe material and will severely shorten the life of your exhaust.  Better off to build a heatshield that clamps on with hose clamps that is directed to the area of concern for the heat, if this is the rear valance or back toward the engine.  The air gap between the heatshield and head pipe will reduce the radiant heat, and allow enough air around the headpipe to cool it. Refer to how the heatshields work on modern motorcycle exhaust, such as any of the current Harley Davidson Bagger platform.  Just my 2 cents after designing and manufacturing various Japanese and Harley Davidson exhaust the last 20 years.  I do think the wrap on the wires like you show, is excellent, have used similar products on my 930 to protect harnesses, in the hot areas of the engine compartment. DEI makes some good material. There is also some other good manufactures. The turbo bags, seem to be effective from what I have heard, haven't had one to know the long term affects, I m sure some other members here have used them and can chime in, or Chris from Turbokraft. I would think trapping the heat in, would play on the life of the turbo itself as well. Good luck in your build! Ben
				__________________ Ben '79 930 Instagram / Duhasst930 | ||
|  11-22-2024, 03:18 PM |
				 | Quote:
|  11-22-2024, 11:33 PM |
			Guys, is this dangerously too close to the lower valve cover, considering how hot the turbine housing gets?! I’m wondering whether the turbo blanket will actually fit within this gap? Haven’t received it yet to test clearances. Thoughts on how I can reduce heat on the lower valve cover to minimise warping/damage?   | ||
|  12-03-2024, 07:57 PM |
| Registered |
			Have you cut away material from the valve cover to provide clearance? Can you even get that cover off for maintenance? For me, that's simply way too close, not just for heat transfer and maintenance issues, but from that pic at least there might even be interference when the engine is running/shifting.
				__________________ '86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! | ||
|  12-04-2024, 06:57 AM |
| Registered Join Date: Jun 2005 Location: Carmichael, CA
			My thoughts.  Don't. Blankets and wraps trap moisture through condensation (when the engine cools) and promotes corrosion, yes even in stainless. A better solution is to have the headers ceramic coated which keeps the heat in the header, reduces convection/radiation to surrounding components, is easy to clean, and (opinion) looks better than raw or wrapped. Additionally, sheet metal heat shields from the turbo hot-side will help as well.
				__________________ 1960 356 Super 90 - EFI'd 1989 190e 2.6 1991 964 | ||
|  12-04-2024, 11:34 AM |
				 | Quote:
 For valve adjustment, there will need to be some disassembly required. lol | ||
|  12-04-2024, 01:31 PM |
				 | Quote:
 Something like this which is only 0.5mm thick: https://funkmotorsport.com/product/thick-aluminium-barrier-heat-shield-0-5mm-thick-sheeting/ | ||
|  12-04-2024, 01:34 PM |
				 | Quote:
|  12-05-2024, 01:27 AM |
