Oil cooler auxiliary fan replacement
Hi guys ,
I plan to replace my still original auxillary fan for the front oil cooler . I checked out the pelican catalog and the OEM Porsche part is expensive and I narrowed down my selection 2 types both of them the push type manufactured by Mocal . The diameter of one model is 5 inches ( total dimension 6 x 4 ) and the other one is 7.5 inches ( total dimension 8 x 2 inches . I would like to know w/c one would be easier to install w/o much modification . It would also be helpful to know if these are reliable / and durable .
Thanks in advance ,
tdh888
Old 10-28-2018, 08:28 PM
https://forums.pelicanparts.com/911-930-turbo-super-charging-forum/994574-oil-cooler-fan-kit-86-930-a.html
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 10-30-2018, 08:37 AM
Thanks for the tip timc . I’m just making sure if it’s the OEM Auxiliary fan is on the way south or if it’s just the relay that needs to be replaced . Unfortunately if Pelican no longer have the German made red round relay , I will be force to buy the Chinese crap relay available.
Old 10-30-2018, 06:10 PM
SO there's an aftermarket fan that is mentioned in that thread, read thru it, I have it and it is far superior to the OEM and the ER fan....
Tim
1986 930
Old 10-30-2018, 06:16 PM
Capt Bob
Capt Bob's Avatar
My aux oil cooler fan problem is a relay problem...curious what the part number is for the relay.
Old 11-03-2018, 04:51 AM
91161510801 is the part no. of the oil cooler auxillary fan . It seems we’re having the same problem . I replaced the relay this afternoon and went for a drive for 45mins . It was hot & humid , got stuck in moderate traffic . Oil temperature never got beyond 9’ o’clock ( using a BMW oil cooler temp thermostat mine is set to turn on the fan at 99 degrees C ) .
Old 11-03-2018, 05:40 AM
Another option would be to bypass the relay and direct wire a toggle switch to the dash. This way you flip the switch when sitting in traffic or during extended idling.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 11-03-2018, 09:29 AM
SBK930's Avatar
Rather than start a new thread regarding oil coolers.
What I would like to know is what type of oil cooler should a 1978 930 have at the front.
I have seen the radiator type mounted in the front fender also the trombone type.
Currently I have the slant nose front cooler below the front bar. However I am considering replacing the front valance with the original style panel.
Steve.
Old 11-03-2018, 01:19 PM
gax gax is offline
Steve.
Hi Steve, 78- 79 930's have the trombone oil cooler as standard. Cheers Greg
Old 11-03-2018, 02:57 PM
I bought a fan from patrick motorsports and wired it up on my own temp controller, its very quiet and has little issue maintaining a safe temp.
1976 914
1986 951
Old 11-03-2018, 03:02 PM
SBK930's Avatar
Thankyou Greg.
I would not think the trombone would be very efficient, however if I am to restore back to factory then that’s what I will have to use.
Cheers
Steve.
Old 11-03-2018, 03:07 PM
gax gax is offline
Your right Steve, they are are not very efficient, although I haven't had any issue in my 79. Spent a bit of time cleaning to removing years of road grime so it dissipates the heat better.
Old 11-03-2018, 07:06 PM
Scottsdale Arizona USA
The 7" Spal pusher fan we recommend. Made in Italy, excellent quality, higest CFM, lowest profile and super reliable. You want to mount the fan as high as possible with the horn set you have.
**Optional updated fan set with the correct 4mm pin harness connector end to match the original fan harness.
911 624 121 00 EPW | Engine Oil Cooler Blower Fan - High Power (437 CFM) 7" Dia Pusher - Includes Original PORSCHE Connector Housing Harness End - For replacement or update of Original 4 Blade Fan Set With Porsche Harness - SPAL / GENUINE PORSCHE / EP-WEST
930 606 118 01 EPW | Temp Switch Sender Kit for Oil Cooler Fan - 911 Carrera / 930 Front Right Oil Cooler | 99 Deg. C (210.2 F) - Includes sealing ring - Correct 4mm Pin For Factory Harness - Direct Replacement - EP-WEST USA
+ Replaces PN: 930 606 118 00 - Temp Switch On Oil Cooler Front Right - 911 / 930 = 118 Deg. C (244.4 F) & 900 123 009 30 - A14x18 mm Sealing Ring
*We also have another fan that is ~1\2 cost instead of the Spal $80 fan above but it doesn't rate as high as the Spal.
911 612 800 EPW | Engine Oil Cooler Blower Fan Harness Set (ORIGINAL STYLE) - GENUINE PORSCHE / EP-WEST
Includes:
(1) Electrical Harness Front Fan Blower Oil Cooler Temperature Switch
(1) Relay
Day @ Euro Parts West, LLC, Scottsdale, AZ USA // Automotive Part Connectors & EPW MODE : Motorsport Design
+1 (844) URO-PART // modepw@europartswest.com
Old 11-04-2018, 10:34 AM
Is that right ? I’m surprised Porsche used the trombone cooler on any 930.
My 81 has the 28 row brass cooler. I’ve always assumed all 930s did until 86 when they switched to the radiator style.
Old 11-04-2018, 01:58 PM
SBK930's Avatar
I must say I am surprised as well. I have seen early 911s with the trombone cooler and thought the early 930 would have had a superior oil cooler due to the performance and heat issues. This is probably why the later than 79 had the radiator style.
And what is the 28 row brass cooler ???
Old 11-05-2018, 01:55 PM
gax gax is offline
I am pretty sure it is. My cars built date is Feb 1979, all stock and it has the trombone oil cooler, Looking at the PET illustrations it also states pre 80 cars had the radiator coil. Happy for someone to state otherwise.
Old 11-05-2018, 05:05 PM
SBK930's Avatar
Hi gax,
Another quick question for you.
Does your 930 have electric door mirrors ?
And I have tracked down and purchased a trombone cooler.
Thanks Steve.
Old 11-06-2018, 11:36 AM
gax gax is offline
Hi Steve, yes it has. On the Porsche certificate of authenticity it's option 261 passenger side plain mirror. Cheers Greg
Old 11-07-2018, 01:06 AM
I know Euro Parts West makes some nice mounting brackets and I’ve seen a couple other approaches, but why not just use the common aftermarket fan mounting kits that hold larger heavier fans on just fine?
Not like we need or want a full shroud for airflow purposes.
I was going to fab up a metal bracket and a long time Porsche mechanic asked why not just use a universal mounting kit.
Edit: I stared at it for a few mins and decided to order a 12”x12”x1/8” sheet of aluminum on Amazon and I’ll make a shroud / mounting bracket ����.
Still, if anyone has any feedback, I’m all ears.
Yay or nay?
1988 Porsche 911 Cabriolet M491 - 3.3 turbo swapped
1994 Toyota Supra TT 6 Speed
2003 Subaru WRX - STi Swapped
2012 Jeep Wrangler Rubicon
Old 07-16-2024, 08:33 PM
I put my own fan together from some parts from Summit. 7" fan and a thermostatic controller. I had a radiator style cooler not the trombone. The thermocouple just pokes between two fins on the cooler.
Works fantastic.
I did have to replace the horns with the little compact Hella ones, but no biggie the originals didn't work anyway.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 07-17-2024, 05:53 AM
