Happiest when Tinkering
gsmith660's Avatar
Coil on plug
Need suggestions on COP setups that work on megasquirt 3
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 07-26-2025, 08:35 AM
gsmith660's Avatar
I have megasquirt 3 so they would need to be compatible with that
Old 07-26-2025, 10:12 AM
I use toyota COPs, they work very well with Microsquirt.
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management.
-1987 Carrera Coupe.
-2013 Carrera S PDK Coupe, factory Aero Kit. My DD.
-1987 928S4.
Old 07-26-2025, 01:53 PM
gsmith660's Avatar
Model number please
Old 07-26-2025, 02:45 PM
Toyota 90919-02246 .. The set I got is a knock-off which I got for about $70 for 6 pcs, I thought I will first use knock-offs so if I did something wrong (excessive duel, driver burn .. etc) its cheap to replace and eventually I will get the OEMs, surprisingly and after about 3 years they still running fine.
-1987 928S4.
Old 07-26-2025, 11:23 PM
flat6pilot's Avatar
If you want to be certain to get the right ones, check with Chris at TurboKraft, they sell Smart Coils that just need a signal wire to fire. The Dumb Coils need the HC (High Current) output from the ECU to drive them.
I found trying to order COP's from various internet suppliers had mixed results and were sent slightly different p/n's that 'should' work. They're not cheap either: In the $60-$120 range each depending on who sells them to you.
You're looking for this p/n: 90919 02234 but it may have been superseded by what Kamaro is using -02246. This is a smart coil. This is different than the 'dumb coil' which is used with the HC outputs on the MS3Pro EVO+ HC
Here's a link talking about COP ignition here on the forums:
https://forums.pelicanparts.com/911-930-turbo-super-charging-forum/812272-cop-ignition.html
Kyle - 1980 RoW non-sunroof 911sc - 3.2 Turbo, Mahle P&C, Carrillo Rods, Megasquirt II (Fuel Only for now), re-geared 3rd and 4th 930 gearbox, 2350lbs
Old 07-30-2025, 12:49 PM
Certified User
billjam's Avatar
I am running 12 Toyota 90919-02246 COPs in my 3.6 (not turbo) and they have been faultless for 15 years. Cheap too.
You will need Toyota connectors 90980-11885.
I cut the mounting lug off the top row of COPs 'cos it isn't necessary to hold them in place and looks neater, but fabbed a mounting strip to hold the bottom COPs in place.
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 07-31-2025, 04:19 AM
Here's a link to the differences in most of the COP's that we'd use (on all but 3.6L).
https://www.newera.co.jp/en/product/communication_site/pdf/419.pdf
If you want it to look pretty, you'll need two different part numbers because of the angle of the connector on the -02246 coil. When installed on some of the cylinders, the angle becomes more obtuse and gets the harness hanging out in mid-air. Can be a problem with a twin turbo setup on the lower coils.
Old 07-31-2025, 06:18 AM
Drive it like u stole it.
jonesb930's Avatar
I am using Bosch COP's for my build. Simon from Motec recommended them (his email is below with data on the coils). I will simply use modified OE lower plug wire retainers to hold them in place.
From Simon Wagner (Motec)_____
"here's something I have had a number of our Porsche-centric dealers use with success:
Dual Bosch 0 986 221 024 coils on one output
Dwell 1.7ms for 10.4A at 14v
Overdwell is 19.2A
Coils are said to fit a Porsche twin plug head perfectly (they fit mine perfectly)
Pin-out
1 = switched Ignition Power
2 = logic ground
3 = EST signal
4 = Igntion High Curent Ground
8v = 7.0ms
10v = 3.0ms
12v = 2.2ms
14v = 1.7ms
16v = 1.4ms
18v = 1.2ms
____________________________
Bill Jones
Jupiter, FL
77 Euro 911 3.0 Wide Body - under construction
http://www.flickr.com/photos/rennsport/collections/72157618856489537/
Old 07-31-2025, 02:37 PM
gsmith660's Avatar
Will these work with megasquirt 3 board version 3.0?
Overdwell is 19.2A
Pin-out
2 = logic ground
3 = EST signal
8v = 7.0ms
10v = 3.0ms
12v = 2.2ms
14v = 1.7ms
16v = 1.4ms
18v = 1.2ms
Old 08-01-2025, 02:08 PM
jonesb930's Avatar
@gsmith660, these only require a logic signal that would normally go to an ignitor, so I don't see why not if the MS3 has an ignition logic output.
Bill Jones
Jupiter, FL
Old 08-01-2025, 02:41 PM
