mark houghton's Avatar
AFR gauges
What are you folks using for AFR gauge setups these days? Eons ago on my first 930 I was using one from Innovate, probably just their base model, and had a bung welded about 10" up inside the tail pipe. Trying to talk myself into going there again. I don't need crazy data logging though that's probably standard anymore.
TIA.....
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 09-13-2025, 08:16 AM
908/930's Avatar
I am using a AEM, so far it works well. Removed the clock and made up a ring to adapt the size but I think there is a gauge that will fit right in properly. I didn't have a good location for the sensor one area slightly too close to the turbo the other too far, ended up going far. Also have a hand held Innovate.
Old 09-13-2025, 11:21 AM
Thanks for the AEM tip.
I didn't seem to have any issues with background ambient air where I had the sensor installed as close to the muffler exit as possible, a good 10" from the end of the tailpipe. Plenty of exhaust flow to negate any ambient air, or so I told myself.
How long is the wire harness? These things are made for front engine setups and if I recall with my Innovate I had to splice in extra wire
Old 09-13-2025, 12:41 PM
908/930's Avatar
I think the other reason they want the sensor closer to engine is to maintain sensor temp. My gauge has an indicator on it and the heater is always on. Likely quicker response and more accurate being close to the turbo. I cant remember how long the cable was, I did order a longer one but not sure if it was for the AEM or Innovate, that was over 12 years ago.
Old 09-13-2025, 01:17 PM
I'm using a PLX with a 2 1/16" gauge from SpeedHut. I'm using a 2 gauge pod I got off Etsy that fits in the dash by replacing the ashtray. They have fonts and pointer styles that are relatively close to the VDO gauges.
1987 930 M505 Cabriolet - Original owner
Mahle 3.4L, K27-7200 QS, Port matched heads, 993 Super Sport cams, Pauter Machine billet forged 4340 connecting rods, 360 lb/in springs, TiAL waste gate, TurboKraft intercooler, Turbosmart PlumBack Uni BOV, Numeric shifter, 993 Cabriolet Top, Rarlyl8 Center exit exhaust
Old 09-13-2025, 05:36 PM
Can you post pics and link to the pod?
Old 09-13-2025, 06:25 PM
https://www.etsy.com/listing/1390712185/double-52mm-aux-gauge-mount-porsche-911
Not the greatest picture
Old 09-13-2025, 06:42 PM
Bucketlist's Avatar
I have used innovate for years and would buy this if I needed a new one:
https://www.innovatemotorsports.com/mtx-l-plus-digital-wideband-air-fuel-ratio-gauge-kit-8-ft.html
You would also need their extension cable to reach a mounting spot in the dash or console.
https://www.innovatemotorsports.com/18-ft-sensor-cable-for-use-with-bosch-lsu-4-9-o-sensor.html
Most recommend mounting the 02 bung between the turbo and the muffler.
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 09-14-2025, 04:07 AM
dlockhart's Avatar
Perhaps a silly question, but how are you routing the cable to the gage? Up the tunnel , or ?.
Old 09-14-2025, 11:14 PM
I'm using Innovate PSB-1 for many years now and its my favorite .. It has the best display and it doubles as a boost gauge and a stand alone boost controller if you want to. It also has many safety features as to boost cut when exceeding a certain boost level or going lean at a preset value.
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management.
-1987 Carrera Coupe.
-2013 Carrera S PDK Coupe, factory Aero Kit. My DD.
-1987 928S4.
Old 09-14-2025, 11:59 PM
Bucketlist's Avatar
Its been several years but if I remember correctly:
From the dash or console under the passenger side carpet near the door to the rear floorboard. Then through the hole in the floorboard below the right rear seat and along the floor pan next to the engine tied up out of the way. Then route it behind the rear bumper to the bung which should be between the turbo and the muffler and at a high angle so not to catch moisture in the exhaust. The 12 ft extension cable is needed.
Old 09-15-2025, 03:16 AM
i have the later AEm digital AFR wideband . The wires were not longer enough. I ending up splicing a few feet of wire into the harness i have mine in the shifter center console. i removed the ac controls and the cassette holders and made a triple pod for a vdo back up boost gauge , fuel pressure and the aem wide band. I ran the wires along the passenger side tunnel( outside ) then used that aluminum hvac duct tape to hold everting tight to the tunnel bottom corner. Then ran through the hole up into my engine bay . i ran extra wires for the other stuff plus it puts the afr plug up in the engine bay and out of the the elements. The AEM wide band came with a bosch sensor it lasted about 2 weeks . i didn't even bother contacting AEM because it was already two years old before i installed it and ebay ones were cheep i installed my bung at 10 o'clock directly off my turbo just before my the muffler. it reads instantly . i purchased a ebay bosch replacement. looked exactly like the Aem . That one failed quickly also. I went to the local Napa bought the same bosch one different box with a online registration code (that one was not cheep ) . The registration code is to prove it was a legit bosch and not counterfeit. This one has been working for over a year no no issues. the AFR gauge is a great tool to have it its a piece of mind . if something feels off you can usually tell if its in your head or an actual issue . Btw i really like the look of snlt930 analog afr gauge.
Ned G. 1976 row turbo i/c k27raptor turbo sc cams in a 80sc wide body
Old 09-15-2025, 04:47 AM
flat6pilot's Avatar
Stack AFR
I really like my Stack gauges. You'll need an extension: https://www.bmotorsports.com/shop/product_info.php/products_id/2170
Kyle
1980 911sc 3.2 Turbo, 930 Trans
2006 BMW 330i 6mt (DD)
Old 09-16-2025, 10:46 AM
Chain fence eating turbo
CIS - Innovate
EFI - AEM all day, everyday, twice on Sunday
Innovate samples too much and can overload EFI’s self-tuning from my experience.
My AFR’s were so much cleaner after going from Innovate to AEM
Old 09-19-2025, 10:26 AM
Originally Posted by Tippy View Post
CIS - Innovate
Thanks. I'm still CIS so Innovate may be a good choice....which is what I had in the past.
Old 09-19-2025, 01:46 PM
I am installing a Fueltech Nano PRO in mine and will run it with a BOSCH 4.9 sensor.
Old 09-24-2025, 12:29 PM
RSR Racer's Avatar
I am monitoring AFR/Lambda on both banks so wanted a dual channel gauge. Ended up going with an Innovate dual channel Lamba gauge that came with the wiring harness and two Bosch O2 sensors. Can be set up to read AFR if you prefer. Works great and has been really helpful in the fuel map tuning and adjustment process.
Made a carbon fiber panel and mounted in my center console with the Innovate alcohol % and fuel temp gauge. Yes, AC is gone...for now.
No issues with the installation or getting them up and running properly. Also, there was plenty of wiring harness to run the wires from the O2 sensors to the center console. Could have run them up into the dash as well.
Old 09-25-2025, 03:36 PM
