Happiest when Tinkering
megasuirt friends help please
Trying to figure out how to post my msq and logs any help would be appreciated
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
Actually I need eyes on my msq and there is no way to upload to the forum
It's a 914 ...
You should be able to. See highlighted button below ...
Fear No Rust
If you post screenshots of your various tables (afr, advance, ve, etc.) you might get comments from people who know tuning but don't have tunerstudio/msquirt.
John
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1105122-driver-survivor-black-1987-930-build.html Real IMSA 914 restoration: http://www.914world.com/bbs2/index.php?showtopic=91937 Basket Case 914 restoration: http://www.914world.com/bbs2/index.php?showtopic=79106 |
That is an excellent idea I will get some screen shots tomorrow
![]() ![]() Here is the VE and spark tables
Let me know what else you would like and I will screensot that as well
The main issue I have right now is when I let off the throttle the car dies I have been trying different settings but havent made any progress
I dont know it did it on ots own
do you have fuel cut on overrun turned on or off?
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! |
not right now do I need to?
My 2 cents.
Based on the other posts the engine runs and idles. I have not used VE to tune before, but the VE table drops to near zero at higher vacuum numbers this could be drying up the intake and causing a stall going back to idle with the throttle closed. I had to finesse my tuning in this area to "catch" or return to idle gracefully after a higher RPM letoff. The ignition numbers look reasonable for twin plug at operating RPM. I would have expected closer to TDC at idle, but this wouldn't stall the engine. Hope this helps.
Lee 1982 Porsche 930 - 3.4L, Motec M84 EFI, BB headers + intercooler, Ruf muffler, K27.2, Turbosmart BOV |
Chain fence eating turbo
Whoa……PSI. I’m accustomed to kPa.
Very hard to understand what the motor is doing in vacuum for me reading PSI. First time I prefer metric over imperial
I will sgreenshot again with proper units
![]() ![]() Ok here they are with proper units and they are the latest map from todays drive
Could be fuel overrun too as suggested. I adjusted my settings a few times to get the balance right. Any datalogging capability for AFR?
i did disable the fuel over run and it helped alot but still will die when I let off the throttle from higher rpm
I would make sure it is off for now, at least for troubleshooting. I noticed a couple of cells with very low Ve
