Talk to me about 930 fuel lines
Hey guys,
as per title. Now I'm quite confused, from the manual and diagrams I've seen the lines I believe are fuel tank through the system to the engine. But then I've watched videos and they're talking purely fuel head and CIS. Can anybody explain to me what's involved altogether and if possible what I need to do to remove the full setup. As my previous post, the car sat for 30 years, thought I had WUR issues, got no fuel pressure so 30 year old pipework may well be the cause. Just a little overwhelmed with the info as I'm new to old porches! Thanks in advance for any help/advice. Rhys |
Drive it like u stole it.
When I first purchased my car 30+ years ago, I too was a bit lost with the fuel system. I purchased the Bosch "Mechanical Gasoline Fuel-Injection System with Lambda Closed-Loop Control" "K-Jetronic" Technical Instruction manual. It breaks down how the whole system works and and includes deep dives into every component. What I learned is just how simple (and genius) this system was for its day. Its a short read, 24 pages in all with lots of diagrams.
The ISBN on mine is: 1-85-226030-0 I did a quick search on Amazon and eBay, its obviously out of print and neither had it but there were others for L & KE Jetronic. Maybe post a WTB in the classifieds. Once you understand the system, purchase a proper gauge test kit with the necessary fittings and you can diagnose issues. Bill
____________________________ Bill Jones Jupiter, FL 77 Euro 911 3.0 Wide Body - under construction http://www.flickr.com/photos/rennsport/collections/72157618856489537/ |
Better yet, get the book Bosch Fuel Injection and Engine Management by Charles Probst...how to understand, service, and modify. 1989 copyright by Bentley Publishers.
Indispensable.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
Talk to Len, @BoxsterGT
He should be able to get you all the lines you need. There are supply and return lines from tank to the engine including the lines through the tunnel, there’s fuel pump lines, there’s the filter, accumulator, fuel head, both fuel pumps. |
Yep, and to feed the lines in/out of the tunnel with a minimum of cursing, you'll want to at least partially drop the engine...
Basically fuel goes from tank to engine and excess fuel goes back to tank.
So it goes: Tank -> fuel line to pump #1 -> pump #1 to tunnel supply line -> tunnel supply line to pump #2 -> pump #2 fuel line to accumulator/filter -> filter fuel line to fuel distributor -> fuel distributor to return line and through the tunnel back to the tank. If you have pressure issues test the pressure at different points in the system with proper gauges and make sure both pumps are running properly. |
a wide band afr gauge is a must you don't want to think its running great and have it be super lean. They run great when they are lean, Then not so good ... if you do eventually rebuild and replace everything fuel related . when you go to set it up you will be like wow it all makes sense and it works . does your car have the three pipe fuel accumulator? if it has a small leak it will blead directly into your return, reducing fuel pressure and you wont know it. The easiest way to test it is remove and dry it out put a balloon on the bottom port and run some compressed air through the supply 100psi and use your finger to close off the outlet side the balloon should not inflate. i saw this post yesterday and have been super busy lately and haven't driven my car in a few weeks. took the old girl to work this morning , The turbos sure like the cooler weather. good luck keep us informed of your progress.
Ned G. 1976 row turbo i/c k27raptor turbo sc cams in a 80sc wide body |
Yeah it's more I'm not kitted up space wise to drop/lower the engine. My garage isn't large sadly (sore subject). So I'll need to find a space/place I can do the work. I have spoken to a few friends who will most likely be able to help! I knew for the bargain price I paid for it that it would need some finessing! lucklily I've worked on many old cars/bikes for a fair amount of years so I'm not phased, more hamstrung by lack of space at the moment! |
I've changed fuel lines through the tunnel without dropping the engine. A little trouble fitting around the transmission mount but not that hard.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
meh, it's easy peasy. Especially just a partial drop as there isn't a lot to disconnect.
Plenty of instructions on here.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! |
Feeling a little better now! haha. Thanks guys. I've got a few old harleys to work on first and then it's prio nr 1! also have a collapsed rear bearing which I'm very much not looking forward to!
for reference here is the ISBN: 0-8376-0300-5 on AMAZON
Crotchety Old Bastard
Bringing one of these back from a 30 year slumber is quite a challenge to say the least. First thing is to $hit can everything fuel system related. The main components can be rebuilt but the lines must be new. If the tank isn't new it must be fully restored, inside and out.
Here is a link to our CIS Primer: https://rarlyl8.com/ That along with the other guides available should give you the knowledge you're after to tackle this. Good luck, we're here to help! .
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
I have done it with both of my cars, never dropped the engine.
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management. -1987 Carrera Coupe. -2013 Carrera S PDK Coupe, factory Aero Kit. My DD. -1987 928S4. |
Fuel tank luckily has been relined/cleaned but all lines are old from what I can tell. Going after the WUR was like putting a banage on a dam it seems! All learning! appreciate the help! |
