930 fuel injectors
Can stock 930 fuel injectors be cleaned or is it better to replace?
They are cheap from vendors like *******(R*oxcxkxAxuxtxox*, some people try back flushing and Porsche used to publish a procedure for this. I have built a little pressure tester from a little hydraulic bottle jack, it allows you to check each injector for pattern and leakage. Cleaned and tested all my injectors, put them in long term storage and bought new ones. They are more similar to the Fuel Nozzle on a T64 turboshaft engine than they are to modern fuel injectors. I have installed, calibrated and provided training for these test stands through work. I wished I could flow my Porsche injectors on that test stand..... But even if I could I would prefer new nozzles to used.
I hve spent some time flushing them - some years ago. I posted some pics etc on it. Held the pitel open with a fine piece of wire and back flushed - gas bottle pressure and a hose clamped over the pintle end and injector cleaner pressure fed thru. Oodles of it. Di it really makie a diffrence? not sure. I am sure if you had a badly blocked one you could relieve it for a while - there is a fine screen on the inlet side.
But really I think new ones are the way to go. Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Crotchety Old Bastard
We have flushed them and re-used just to have them fail again a few months later. The root of the problem is they are worn out. New injectors significantly improve idle and overall smoothness of engine operation.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
What is the best injector replacement up to 400 whp?
My worst fear is that when I die, my wife will sell my cars for what I told her I paid for them |
I am just running standard injectors. Your main limitation will be fuel delivery.
Alan
The injectors do not set the fuel flow, CIS fuel head determines the flow to each injector, the injectors is better described as a fuel nozzle, it creates a pattern and atomizes the fuel delivered to it. That being said the euro fuel head (cast iron painted black) had larger lines to each injector, and different PN for the injector, 400 HP on CIS is probably beyond the fueling capabilities of a stock US spec system. The euro spec non lambda system may work better.
The Euro -009 fuel injectors support the most flow by volume. The -017 USA injectors (with skinny lines) will still support 400+whp. The Euro fuel distributor (-037)will support ~375whp in stock form, USA (-145) ~350whp at best.
its working fine for me. making 400 at the wheels, no sign of being fuel limited
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! |
Old Codger
Cleaned my 009 originals a few years ago. If I had to do it again I would buy new ones.
The cleaning seemed to work out and supports all the HP I ask for. |
Can anyone provide a reputable seller or brand for injectors?
From our host:
https://www.pelicanparts.com/search/?q=injector
Steve 1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters. |
