-   -   930 Intake Boot? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/312530-930-intake-boot.html)
WydRyd 10-31-2006 03:53 PM
930 Intake Boot?
Gang,
I'm planning to use a hard OEM 930 intake pipe (which goes to the compressor inlet) and I'm curious to know if these came with some sort of "intake boot" or sleeve, which stepped it up from 2.75" OD to 3.0" OD?
Here's a pic of what I'm talking about:
http://forums.pelicanparts.com/uploa...1162338750.jpg
Advice appreciated SmileWavy
AFJuvat 11-01-2006 05:06 AM
The hard intake pipe had a rubber boot on both sides:
part number 930.110.158.01
AFJ
David 11-01-2006 11:46 AM
I believe the OD of the pipe and compressor inlet are the same on the stock turbo.
WydRyd 11-01-2006 05:27 PM
Yeh, it's going to be a mismatch for me as I'm going to run a Garrett GT35R BB turbo, which has a 3.25" inlet on the compressor, so I have to step it down to 2.75" if I use one of those 930 inlet hard pipes :confused:
The turbo has a straight 3.25" to 3.0" silicone reducer on it, so I have to reduce it down further to 2.75" :(
930turbo 11-01-2006 06:05 PM
Check out this site. Maybe they have what you need.
http://hosetechniques.com/
Ken911 11-02-2006 06:08 AM
I had to double hose mine. A lot of people do it that way just cut a short piece of the smaller hose to fit the hard pipe then slide the larger hose over the top and clamp it down good.
WydRyd 11-02-2006 08:29 PM
AFJ
Does this part step up the OD of the hard pipe to 3.0" ?
