Twin plug + CIS - what is your timing set at?
Just curious. I have TP, IA fuel head, adjustable WUR, etc - curious what others run their timing at?
Mine is at 5 BTDC at idle & 22 at 4k/up with advance/retard plugged. Changing to 10 BTDC idle & 26 4k/up upon recommendation of original TP builder. |
dyno and advance timing until torque does not increase...
Joe has it right on - was curious what others timing has ended up as -
thanks. |
Actually, a good question. Usually can't hear it in our cars.
IMO, setting the timing per JoeMag is the way to do it - this is why setting the timing on an engine dyno or loadable dyno is the best way to tune. I'm fortunate to have the spec form the prior build - derived from the engine dyno in 2004. |
If you are very off-base on turbocharged engine (wastegate ruptured, very lean, fuel depletion etc.) it will sound like somebody took a hammer and started knocking on the engine. It's usually an expensive sound. Compression rings will often crack. Prolonged knocking of this magnitude ("prolonged" can be as short as 5-10 seconds) might end ut with holed piston. 911 pistons will mostly develop holes on it's edges, seldom in middle. |
I've LONG heard from Steve Weiner and others that most knocking in our engines cannot be heard - subaudible, "you hear it and it is too late"
Not busting your balls on this, but it is directly contradictory to all that I have heard from some very credible people. |
I've heard it as a metallic rattle. I call it the death rattle. Haven't heard it since the last rebuild, though.
:rolleyes: |
Odd
I'm on Electromotive XDi, so I read my timing with a multi-meter connected to the ignition ECU. I also have a MAP sensor. At start up, my idle timing is 15 degrees. At cruising (on the interstate, no boost, around 80-90 MPH) it's about 24 degrees. At full boost WOT, the MAP sensor quickly drops my timing to 20 degrees.
Does idle timing - which is 'too retarded' - cause a rough idle?
My past experience with a normally aspirated engine revealed less spark lead was necessary after added the second plug. The dyno proved it. If you think about it, you're starting two flame fronts in the same combustion space - therefore taking less time to develope maximum cylinder pressure. Sand Man stated his results were similar relative to stock. The engine I experimented with had as much as 35 degrees lead in single ignition form. The end result after adding the second plug was 20 degrees total @ WOT. Both CHT & EGT went down with the second ignition installation. Mid-range power was the most noticable change in power.
930turbo -
Jim |
Exactly what I also have heard - accounts for my 26 degrees rather than the usual 29.
| All times are GMT -8. The time now is 06:26 AM. |
