Me like track days
Craig 930 RS's Avatar
Question Twin plug + CIS - what is your timing set at?
Just curious. I have TP, IA fuel head, adjustable WUR, etc - curious what others run their timing at?
Mine is at 5 BTDC at idle & 22 at 4k/up with advance/retard plugged. Changing to 10 BTDC idle & 26 4k/up upon recommendation of original TP builder.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 11-04-2006, 02:20 PM
JoeMag's Avatar
dyno and advance timing until torque does not increase...
Old 11-04-2006, 03:13 PM
beepbeep's Avatar
...Or knock sets in...
Thank you for your time,
Old 11-04-2006, 06:50 PM
Me like track days
Joe has it right on - was curious what others timing has ended up as -
Old 11-04-2006, 06:55 PM
dumb question - how does one tell knock sets in?
thanks.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 11-05-2006, 06:15 AM
Me like track days
Actually, a good question. Usually can't hear it in our cars.
IMO, setting the timing per JoeMag is the way to do it - this is why setting the timing on an engine dyno or loadable dyno is the best way to tune. I'm fortunate to have the spec form the prior build - derived from the engine dyno in 2004.
Old 11-05-2006, 09:40 AM
Really, I can hear it just fine. But that must be my uneducated ear.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 11-05-2006, 03:08 PM
beepbeep's Avatar
thanks.
You usually hear weird sound from engine compartment that sounds like a bunch of BB's rolling around in a barell. It's pre-ignition in it's mild form. If you hear it, back on ignition timing / enrichen the fuel / lower the boost. Engine will hopefully survive if it catched early. It's audible enough to be detected by ear from inside of the car.
If you are very off-base on turbocharged engine (wastegate ruptured, very lean, fuel depletion etc.) it will sound like somebody took a hammer and started knocking on the engine. It's usually an expensive sound. Compression rings will often crack. Prolonged knocking of this magnitude ("prolonged" can be as short as 5-10 seconds) might end ut with holed piston. 911 pistons will mostly develop holes on it's edges, seldom in middle.
Old 11-05-2006, 03:18 PM
Me like track days
I've LONG heard from Steve Weiner and others that most knocking in our engines cannot be heard - subaudible, "you hear it and it is too late"
Not busting your balls on this, but it is directly contradictory to all that I have heard from some very credible people.
Old 11-05-2006, 03:44 PM
I've heard it as a metallic rattle. I call it the death rattle. Haven't heard it since the last rebuild, though.
Old 11-05-2006, 05:57 PM
GJF GJF is online now
Slantnose from HELL
GJF's Avatar
It changes from time to time.....
Old 11-05-2006, 06:47 PM
Me like track days
Odd
Old 11-05-2006, 07:18 PM
resident samsquamch
sand_man's Avatar
I'm on Electromotive XDi, so I read my timing with a multi-meter connected to the ignition ECU. I also have a MAP sensor. At start up, my idle timing is 15 degrees. At cruising (on the interstate, no boost, around 80-90 MPH) it's about 24 degrees. At full boost WOT, the MAP sensor quickly drops my timing to 20 degrees.
-jeff
Old 11-06-2006, 10:56 AM
Me like track days
Does idle timing - which is 'too retarded' - cause a rough idle?
Old 11-06-2006, 10:58 AM
930turbo's Avatar
My past experience with a normally aspirated engine revealed less spark lead was necessary after added the second plug. The dyno proved it. If you think about it, you're starting two flame fronts in the same combustion space - therefore taking less time to develope maximum cylinder pressure. Sand Man stated his results were similar relative to stock. The engine I experimented with had as much as 35 degrees lead in single ignition form. The end result after adding the second plug was 20 degrees total @ WOT. Both CHT & EGT went down with the second ignition installation. Mid-range power was the most noticable change in power.
'77 930 turbo Garretson I/C 1 BAR spring, (2) '82 Triumph Bonneville Royal Wedding Edition
Past rides: '74 914 1.9 liter twin plugged track car, '83 928S, '87 924S, '75 911S w '78 ROW 3.0, '72 911T, '70 911T and various other insignificant domestic examples. Happiness is a grey tailpipe! Turbo lag......it's worth the wait!
Old 11-07-2006, 05:25 PM
7.0:1 > 11.3:1 > 7.0:1
930turbo -
This is exactly what I noticed too, but I was unsure what specific change attributed to it. Good to confirm this.
Jim
Old 11-07-2006, 06:14 PM
Me like track days
Exactly what I also have heard - accounts for my 26 degrees rather than the usual 29.
Old 11-07-2006, 06:27 PM
