msd cdi box
Does any one run an msd ignition box ? I was thinking of a slight upgrade because my tach relay bit the dust and i could take out 20 year electronics and use new state of the art with rev limiter built in.
1986 blk 930
2000 expedition
2000 bmw 3 series convertable
1996 Silverton 312 sedan bridge
Old 11-08-2006, 02:31 PM
Me like track days
Craig 930 RS's Avatar
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 11-08-2006, 02:52 PM
A930Rocket's Avatar
I use the MSD6AL. Because my car has no rev limiter, I really like the "soft touch rev control". My shift light comes on at 6k and the limiter comes on at 64k.
Old 11-08-2006, 04:12 PM
Crew Chief
prooutlaw's Avatar
6AL here, works great
Herbert B.
GruppeB #093
Carolinas Region PCA Member
National PCA Driving Instructor
_______________
'71 911 RSR look
'74 914 2.0
'76 911S Targa
'83 930S Slantnose (13000 miles)
'86 951 Prototype Testcar built in '84 (56000 miles) Serial #00014
'86 951
'87 944
"Life is short , drive Fast"
Old 11-09-2006, 05:29 AM
ok put in the msd 6al box now she sputters and wont do much more then a crappy idle sort of . Did I need to change the coil ? car won't really run, is there a different wiring diagram I should use.
1986 blk 930
2000 expedition
Old 11-19-2006, 02:56 PM
A930Rocket's Avatar
Yes. Change to a Blaster 2 coil. I'd get the one that you can set in any position, i.e. upside down.
Did you wire it right? You have to make sure you wire it right to the distributor.
Courtesy of Steve Weiner:
Me: Since the Turbo uses a magnetic pick up type distributor, my question is which wire does the MSD violet wire connect to and which wire does the MSD green wire connect to from the wires coming out of the distributor? Does the MSD green connect to the coaxial center wire or sheathing wire? Or does it even matter which one I connect to?
Steve: ANSWER: You are right in that the violet & green wires conduct the trigger voltage to the MSD. This is phase sensitive and must be connected correctly otherwise the car will not start or run poorly. Connect the center conductor to the green wire and the shield to the violet wire.
Old 11-19-2006, 05:42 PM
O.K. new coil checked wires runs good seems rich. The problem seems now I have a high idle 1..4k won't lower with idle screw checked all vacum lines no leaks. I think it must be very rich . I will lean it out and see what happens.
1986 blk 930
2000 expedition
Old 11-20-2006, 01:57 PM
The idle is still high and the engine is still rich. Before I go and try to do huge rich/lean adj do you think the wur is sticking ?
1986 blk 930
2000 expedition
Old 11-21-2006, 02:53 PM
A930Rocket's Avatar
Have you checked your timing? If it's advanced, it will idle higher.
You should dyno the car to get the A/F ratios right.
Old 11-21-2006, 06:42 PM
