-   -   Twin plugging with 964 twin dizzy? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/315683-twin-plugging-964-twin-dizzy.html)
JoeMag 11-17-2006 10:36 AM
Guys -- Has anyone here done this on 930 in their efi conversion? What is involved? At first blush seems like a much easier (and maybe less costly?) conversion than multi coils w/trigger wheel on crank.
--Joe
Rob 930 11-17-2006 10:59 AM
Joe,
There are pros and cons to doing this, which I'll let others hash out. But it can be done with a twin distributor (which used to be debated). Here's a thread where I posted a pic of an EFI 930 with a 964 distributor.
Pelican thread
Rob
JoeMag 11-17-2006 11:39 AM
Rob -- thx. ...that an old post so I'm hope'n some folks can give details of how done.
YermanCars -- I just was reading another post and see you're going to do this. What's required?
mb911 11-17-2006 12:23 PM
saw that to. Also saw his for sale thread. I wonder if he is supercharging it or something as he was talking about DE's etc.. Anyhow on topic I think the EDIS is the way to go its pretty cheap if you already have EFI . if not go the dizzy route
JoeMag 11-17-2006 01:54 PM
EDIS?,,... don't recognize that.
Lukesportsman 11-17-2006 02:51 PM
Crank fired (timed to cam, obviously) distributorless ignition with typically multiple coil packs. Think new car applications applied to our older cars.
Many are using the Ford packs, which I also plan to do. There are some articles here and elsewhere...usually in reference to TECII or MegaSquirt type EFI's though obviously others apply.
A930Rocket 11-17-2006 03:32 PM
If you use a 964 dizzy, don't you have to change the gear drive on the crank?
Lukesportsman 11-18-2006 04:26 AM
Like 930Rocket suggests, don't SC and 930 engines require a reverse rotation dizzy or gear swap?
YermanCars 11-21-2006 06:00 AM
I have not done it yet, but I will over the winter. The reason I am doing it is because I purchase a SDS efi system that uses the distributor for ignition, not coils. I was force to this path because of it. I will be running 2 ignition boxes, 2 coils and the 964 twin dizzy. I believe on a 3.2, I don't need to change the gear, but on the SC and 930's you do.
YermanCars 11-21-2006 06:02 AM
I would never supercharge my Porsche. I am maybe looking to change my setup around a little.
mb911 11-21-2006 06:19 AM
glad to hear. Can't wait to see the next setup.. good luck
JP911 11-28-2006 01:00 PM
964 distributor will require a 3.6 dizzy drive gear on the crank. Contact Steve Weiner at Rennsport Systems for more info.
WydRyd 11-30-2006 04:03 PM
That's for the 930 and SC's right? For the 3.2 Carrera, it's simply a drop in affair?
Can someone plz verify?
YermanCars 11-30-2006 04:25 PM
Yes, The twin dizzy is a plug and play w/ the 3.2.....
