-   -   need a cheap way to retard timing (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/315766-need-cheap-way-retard-timing.html)
afterburn 549 11-17-2006 07:52 PM
is there a cheap box that will retard timing when things start to come on to boost ?? this is on a dizzy, cis sys. 2.7 just so everyone can say.........she's gonna blow !!
BoxxerSix 11-17-2006 08:17 PM
Cheap, not that I'm aware of. MSD produces what's called a BTM or Boost Timing Master ignition module that can retart timing up to 15 degrees in 1-3 degree-per-psi increments but it may need to be modified to work with a dizzy. It is an ignition module in itself(amplifier) and works well with single coil ignitions but I've never personally put one to use on a porsche engine. I did have one equipped on a different turbocharged vehicle I owned in the past and it worked very well.
Regards,
iamchappy 11-17-2006 08:34 PM
I am running a MSD BTM on my turbo 3.12 engine it receives the boost pressure from a vacuum line running off of the throttle body, works very well. I have twin plug and have both Blaster coils running pigtailed from the MSD per Henry at Supertec's recomendation. There are some that disagree with this setup but Supertech's never had a problem with it.
RarlyL8 11-17-2006 08:49 PM
You don't necessarily have to retard your timing on boost. The early 930s did not have a timing retard function, full advance was set at 28*. Your timing curve will depend on how much boost you run, what your C/R is, fuel octane, and single vs twin plug.
I assume you have standard low C/R 2.7L with single plug and pump gas with maybe 0.5bar boost. Should not need to retard on boost, just tune it well.
BoxxerSix 11-17-2006 09:17 PM
The only thing I've ever heard about using the BTM with dual coils is overloading the driver circuit if the impedence of both coils is too much for it. If Henry says it works and it is in fact working for you then that's good news because I could really use it for a future 3.6 project.
Which Blaster coils are you running(part numbers) and could you possibly run a primary/secondary ohm reading on the coils for me? It would help me out alot in setting up something like thi in the near future :D
930turbo 11-18-2006 05:45 AM
Here's another cheater short cut for single MSD & twin plugged applications. Go to your local high performance motorcycle shop and purchase an aftermarket coil for just about any in-line four super bike. They use twin-lead coils fired by a single signal input.
BoxxerSix 11-18-2006 01:30 PM
Actually cheaper and easier to buy for v-twin applications. Referred to as dual fire coils. Nology, Dyna, Compufire, Crane....just about all the big name companies make one or more models to suit. Used in waste spark applications on V-twin. Good idea though for a crank trigger setup.
And if someone wants to try the above avenue of "twin pluggin", go with Compufire as they just produced a low ohm dual fire coil that works great with DIS ignition modules.
afterburn 549 11-18-2006 02:30 PM
good onfo here as per usual Thanx !!
Jim2 11-19-2006 08:09 AM
How much is a 930 USA distributer compared to these electronic options? I realize it won't provide adjustability, but it's bolt in and will give you boost retard.
afterburn 549 11-19-2006 08:12 AM
Hmm..... that might be a real good idea...got one ??
Rob 930 11-19-2006 12:00 PM
You might be able to pick up an old Electromotive setup, like the TEC-1, and use just the ignition side of it (not the fuel side). I did that on a previous iteration of my 930 and got twin ignition and a fully programmable timing "curve" that used a MAP sensor for boost retard. A complete setup can probably be had for less than $1K.
Jim2 11-19-2006 01:09 PM
Sold mine to gpc turbo. You might check with him or throw up a wanted ad. Should be a good handfull of them sitting around.
Jim
A930Rocket 11-19-2006 05:50 PM
Will the Electromotive XDi ignition system work? It's about $1175 for single plug version.
afterburn 549 11-19-2006 06:55 PM
holy smokes batman I mean cheap, cheaper ,cheapest, and lots less then that ....some one some where has got to have an old 930 dizzy under their bench taking up way to much space.......................If I throw a grand at it for a stand alone I might as well throw two more and get it over with and have injection too!!
A930Rocket 11-20-2006 10:23 AM
When you're talking Porsche, this is CHEAP! Sounds like you're talking FREE! :)
afterburn 549 11-20-2006 05:38 PM
one can always hope........................
RarlyL8 11-20-2006 07:27 PM
930 distributors "generally" go for $200-$300 depending on year and condition. If you do a search you will see a few have sold here on the board.
afterburn 549 11-20-2006 07:39 PM
I guess I am whacked ?? If I were taking this proj serious I would go with a complete stand alone sys. In my brain I see these dizzy(s) as "antiques" and who could want one ? cept for me of course in my blow it to Shynoah configuration...............
