Porsche Crest 1979 930 Fuel Injector Opening Pressure
So I've taken it upon myself to test pop test all my injectors. I noticed that 4 of my injectors opened up at 40 psi, but 2 injectors opened at 38 psi and 39 psi. Is this bad? Shouldn't they all open up at the same psi or is it that the spray pattern really matters more? I'm just curious. These injectors come from a CIS system on a 79 930.
Old 01-08-2007, 08:13 PM
David's Avatar
Since they spray continuously, I can't imagine that the opening pressure would matter much.
Old 01-09-2007, 01:44 PM
Me like track days
Craig 930 RS's Avatar
Your pressure differences are fine.
It (can) matter(s) quite a bit. According to the local guy who does injectors/tested mine, the opening pressure ("crack pressure")
coincides with injector leakage. One of mine opened way too early (about 8 psi too early and 'flowed' a ton more than the rest......and consequently dribbled profusely when the crack pressure threshold was reached on the way down.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 01-09-2007, 02:58 PM
Crotchety Old Bastard
RarlyL8's Avatar
38 to 40 pounds cracking pressure is not significanly different. You should be fine as long as they are not leaking when closed.
Old 01-10-2007, 04:05 AM
Me like track days
Isn't that what I just said?
Old 01-10-2007, 05:35 AM
A fellow Pelacanite
NathanUK's Avatar
it's always nice to get a second opinion even if it is worded a different way.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 01-10-2007, 02:15 PM
