Wastegate Fitting
Looking to source a wastegate fitting similar to the one circled in the attached pic. If you have any suggestions or may have an extra please let me know.
Thanks!
montgomery.ra@gmail.com
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 01-08-2007, 06:17 AM
7.0:1 > 11.3:1 > 7.0:1
Though I'm sure there are suppliers for these banjo fittings, I know they are a similar size to many of the hard-line banjos used on various parts of Bosch fuel systems. I scavenged one which I used for the top of my wastegate. If I recall correctly it either came from the output end of a Bosch fuel pump, or around the fuel head on a VW jetta. Used the same bolt thread too.
Jim
Old 01-08-2007, 08:34 AM
I cut and used the oil line on timing case Its the samething..
Old 01-08-2007, 06:55 PM
Priced-out of Porsches.
mmastro's Avatar
This might be it? I email you, too.
Mike
SoCal
Old 01-10-2007, 08:29 PM
Mike that does look like it could be what I am looking for. Unfortunately I don't know the size of the one I am trying to replace. Do you know if that is from a stock wastegate?
Rob Montgomery
Old 01-11-2007, 04:50 AM
