935TURBO's Avatar
New sway bars mount......D.I.Y.
One month ago....I had a problem, exposed on that thread.......
I need some help for sway bars......
So, one month later.......here's my solution.........hope that'll be correct.......
Serge, Gentleman Driver
https://www.facebook.com/photo.php?fbid=10207116408000968&set=gm.1723624077 855805&type=3&theater
Old 04-23-2008, 12:43 PM
935TURBO's Avatar
URL=http://imageshack.us][/URL]
Following....
[URL=http://imageshack.us][/UR
Old 04-23-2008, 12:44 PM
Adrenaline Junkie
Hayabusa's Avatar
Nice fab. Looks like it could handle ANY situation.
Old 04-23-2008, 02:09 PM
full quack's Avatar
Send a message via Yahoo to full quack
Ummmm... thats all well and fine, but...wow...a lot of work!
I have to wonder why you didn't just buy those really nice Wevo brackets and simply weld them in place.
My 2 cents worth of pondering.
Mark
Old 04-23-2008, 07:58 PM
935TURBO's Avatar
Mark
Hi Mark,
I did those mounts myself only because my car is a collector, and I don't want to make modifications who wouldn't be reversible......and I'm not so sure that the Wevo brackets were so easy and faster to fit on the body.....with destroying and recreating fuel pump mount......
Old 04-23-2008, 11:22 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
Good job Serge, In the states the WEVO's are probably more accessable too. Those fabbed mounts are definetly going to be strong, stonger than the WEVO units
It changes from time to time.....
Old 04-24-2008, 04:34 AM
935TURBO's Avatar
Thanks For the compliments GJF.......I understand that it's a lot of work for only 2 mounts....but, that's not too much for such a car that I'll keep as long I'll be alive....and my son who helped me is close to seventeen...so......
P.S.: and those brackets are not taking place of the stock ones....but added to the stock ones...that'll be normally much more stronger than only replacing.....
Old 04-24-2008, 05:04 AM
930gt-40r's Avatar
Serge,
That is a really nice job that you did with that. Now did you do that in place of buying Wevo weld in mounts or was it because the sway bars needed to be adapted to fit the car?
Either way a really nice job.
If you did them, what did you think about installing the through body swaybar in the front? Was it a pain in the @ss? I have to do the conversion soon and want to gather as much knowladge as possible soon.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 04-24-2008, 05:23 AM
935TURBO's Avatar
Hi Kris....as I said upper, I didn't want to pull out the stock mounts and didn't want to weld on the body.....the other thing is that I analysed the picture i saw on my other thread from cl8ton (http://forums.pelicanparts.com/uploads12/100_08921206668692.jpg) and tried to understand how the efforts are on those mounts.....then, I decided to make my own ones, keeping the collector side of my car....
Of course, next step will be to fit the front bar...and reinforce the body in consequence.....hard job....pull out the tank and so on.....
Old 04-24-2008, 07:27 AM
turboteener's Avatar
If you grind the weld joints free of the mill scale on that angle iron it will weld much better.
Brett
Old 04-24-2008, 10:09 AM
full quack's Avatar
Ah yes...walking that thin line between wanting to leave it dead stock for ultimate resale /collectors value, and wanting better than stock performance. With the Wevo's being weld on, you would of had to cross that line....I understand completely.
Mark
Old 04-24-2008, 11:24 AM
