-   -   RUF Input Shaft (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/329089-ruf-input-shaft.html)
carmad 02-06-2007 07:05 PM
RUF Input Shaft
The input shaft in my RUF 5 speed is bent after an accident. Does anyone know if it is a custom RUF part, or is it a Porsche 930 stock part? Any info would be much appreciated.
930gt-40r 02-12-2007 08:26 PM
OOOOUCH! I believe it may be as the stock trans in the car is a 4 speed and that is one of the points that Ruf modified. If it is indeed and you find a distributer that carries them, let me know how much because I want to convert my car someday.
NathanUK 02-13-2007 03:06 AM
Julian, why not take it, or send it to someone that rebuilds 930 boxes. They may even have one apart that they could compare it to.
Easier still take some pics of it beside a tape measure or ruler...
carmad 02-13-2007 06:25 AM
Thanks guys.
The tranny has not been taken apart yet, measured with dial indicator shows its bent. Next step is to take it apart and really inspect the rest of the internals.
I'm hoping its a stock shaft!!!
NathanUK 02-13-2007 12:51 PM
One of the manuals I have mentions checking the runout & straightening a 915 shaft if needed. Maybe yours could be straightened & then hardened or treated afterwards ? I would give Guard transmission a call.
carmad 02-13-2007 02:19 PM
Thanks, I will look into that.
89turbocabmike 02-17-2007 11:28 AM
Julian, I was perusing Bruce Anderson's book(yet again) and there is picture (pg 231) of the RUF 5spd showing the major components which are different. Both the input and pinion shaft are longer:(
David 02-17-2007 12:23 PM
Have you called RUF in Dallas?
carmad 02-17-2007 08:34 PM
Mike, have that picture it looks longer as you said.
David, Yes, I called RUF last week, they were going to contact Germany,still waiting for a reply.
