afr guage placement
Where are you guys with afr guages, installing them in the cockpit I would like to put mine in the center console somehow, but there is too much junk in there already. central locking and ac controls.
I have mine with a shift light and boost gauge on the left pillar
I also am installing a fuel pressure gauge for added safety since I have aftermarket fuel pumps
http://forums.pelicanparts.com/uploa...1171317233.jpg |
I have an innovate WB system and gauge. I made a small aluminum bracket that is double stick taped(auto trim stuff) to the steering column so that I can see it while on boost.
http://forums.pelicanparts.com/uploa...1171342039.jpg http://forums.pelicanparts.com/uploa...1171342094.jpg http://forums.pelicanparts.com/uploa...1171342117.jpg http://forums.pelicanparts.com/uploa...1171342133.jpg http://forums.pelicanparts.com/uploa...1171342169.jpg |
Those are some sweet setups! Thanks for the pics.
I tried it on my steering wheel colum but it was to low and to close to me . I can hardly read the gauges so it easier to see the gauges higher and to the side. I am also 6'4" .
It took a little work, but I was able to mount mine in the ashtray...
http://forums.pelicanparts.com/uploa...1171415816.jpg |
http://img238.imageshack.us/img238/6...s024wj8.th.jpg
Mine is a fairly inexpensive (~$400) WMS. I am currently doing a CIS to M48 conversion and don't know if this will work with the new setup, so I may have to get rid of it. But regardless, it is small enough to fit into the slot at the bottom of the center console. |
Re: afr guage placement
http://forums.pelicanparts.com/uploa...1171642211.jpg http://forums.pelicanparts.com/uploa...1171642230.jpg http://forums.pelicanparts.com/uploa...1171642245.jpg |
Steven P., where did you get those A-Pillar gauges and mounts? :D
kas930, job well done mate, that looks factory.
I have a small digital guage mounted on a bracket just below the speedo. Easy to see. I also have toggle switch mounted to switch the display between the left bank and right bank of cylinders (on a NA motor mind you)
cheers |
[QUOTE=kas930;3101449]It took a little work, but I was able to mount mine in the ashtray...QUOTE]
Nice job kas... I really like that! Right color for my car too! P- |
Definitely funtional but I want a more factory look like the molded pods offer...possibly covered in leather. RT |
| All times are GMT -8. The time now is 09:01 PM. |
