afr guage placement
Where are you guys with afr guages, installing them in the cockpit I would like to put mine in the center console somehow, but there is too much junk in there already. central locking and ac controls.
I have mine with a shift light and boost gauge on the left pillar
1986 blk 930 2000 expedition 2000 bmw 3 series convertable 1996 Silverton 312 sedan bridge |
Bill 997.2 |
I also am installing a fuel pressure gauge for added safety since I have aftermarket fuel pumps
I have an innovate WB system and gauge. I made a small aluminum bracket that is double stick taped(auto trim stuff) to the steering column so that I can see it while on boost.
Those are some sweet setups! Thanks for the pics.
Bill 997.2 |
I tried it on my steering wheel colum but it was to low and to close to me . I can hardly read the gauges so it easier to see the gauges higher and to the side. I am also 6'4" .
It took a little work, but I was able to mount mine in the ashtray...
![]() Mine is a fairly inexpensive (~$400) WMS. I am currently doing a CIS to M48 conversion and don't know if this will work with the new setup, so I may have to get rid of it. But regardless, it is small enough to fit into the slot at the bottom of the center console.
Olli Selander 1989 930 - 3.5l - M48 - G64/51 Last edited by oms930; 02-14-2007 at 05:59 AM.. |
Re: afr guage placement
Phil 2005 GT3 Milltek Exhaust/ECU reflashed/OEM Short shift 1988 911 coupe (GP white) Turbocharged 1998 BMW 328i |
Steven P., where did you get those A-Pillar gauges and mounts?
kas930, job well done mate, that looks factory.
In Heaven… the mechanics are German, the chefs are French, the police are British, the lovers are Italian and everything is organized by the Swiss. In Hell…the mechanics are French, the police are German, the chefs are British, the lovers are Swiss and everything is organized by the Italians. |
Inquiring minds want to know!!!
WTB: 964/965 Turbo stuff...carbon fibre bits, Techart wheel parts, RS/lightweight flywheel, 993 EVO uprights, G50 gears or 6 sp., 964 RSR swaybars, custom droplinks and any other cool stuff, pm me! Also a nice medium build 327 Chevy engine. Coming SOME DAY...1991 3.3 turbo, Tahoe Blue Metallic with some mods
I have a small digital guage mounted on a bracket just below the speedo. Easy to see. I also have toggle switch mounted to switch the display between the left bank and right bank of cylinders (on a NA motor mind you)
cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
[QUOTE=kas930;3101449]It took a little work, but I was able to mount mine in the ashtray...QUOTE]
Nice job kas... I really like that! Right color for my car too! P-
RGruppe #180 So many cars.. so little time!! |
Mine on the pillar..
![]() 914 6 Turbo twinplug 3.12 87 924S Lexus SC400 Lexus LS400 |
I take it you just screwed the bracket into the pillar?
Definitely funtional but I want a more factory look like the molded pods offer...possibly covered in leather. RT
