-   -   Weak BOV Spring = no boost ??? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/339019-weak-bov-spring-no-boost.html)
hobieboy 04-02-2007 05:19 AM
I have just replaced my GSF BOV with a Tial 50mm unit and now I don't have any boost :(
I haven't double checked to make sure I reconnected all the hoses 100% correctly, but I crossed my mind that since I specified a fairly weak spring (-9psi) for the BOV, could it be what causes the problem?
I thought if I keep my foot in, the BOV should NOT open even with a weak spring? :confused:
Any comments / suggestions?
Thanks!
mb911 04-02-2007 07:35 AM
I choose the same spring for my setup and it works perfect. Can you here it expelling? If not recheck your IC connections.
hobieboy 04-02-2007 07:41 AM
On throttle lift (from cruising to total lift), I can hear it vent faintly. So I assume its opening properly.
Could it be that it is opening too soon/too much while I try to build boost?
I'll definitely check the IC, & intake tract connections tonight but thought I'll jump the gun & ask for input about choosing wrong BOV spring tension...
mb911 04-02-2007 01:52 PM
interesting I only am building .4 bar and it works great for me!
hobieboy 04-03-2007 09:09 AM
As Ben suspected, I re-checked my IC connection and one of the hose slid off just a tad causing boost leak.
Didn't have a chance to really gun it but the one short chance I have, boost is shooting up to 0.6 bar already very quickly. Looks like I have solved the problem :D
David 04-03-2007 10:14 AM
I guess my 50mm Tial has the stock spring, whatever that is. When it was on the dyno, I noticed it opening when the throttle was closed even at very low loads. I never saw it open under boost.
hobieboy 04-04-2007 04:25 AM
David, when I still had boost leak, I could hear a nice "faint" whoosh as I lift throttle from cruise.
Now, there's a fairly loud rumbling when I lift - sound more like turbulence kinda rumbling. To be honest, not a very pleasant sound; though my old one did the same.
Do you guys have similar experience?
David 04-04-2007 04:52 AM
Mine made a slight woosh when lifting at low loads and the louder woosh when lifting at full boost. I don't recall a rumbling sound.
hobieboy 04-04-2007 02:22 PM
umm... maybe I should try to record the sound and upload it.
Mine does sound quite violent. The location is very similar to where the standard one is (between turbo & the intercooler input).
