RUF intercooler re-do, clean up and replumb project
1) Glass bead blasted the RUF intercooler - took 1.5 hrs - P21S wax on top
2) Cleaned up wiring for the RPM full boost enrichment delay switch 3) Adjusted the WUR to lower the warm control pressure for a bit more rich in the midrange 4) NAPA has a silicone paste which is ideal for sealing the IC rings 5) Rerouted/replumbed the 'IC in' temp sender from the air cleaner to the IC inlet |
She-it.......hang on, pics aren't working........
Ah.. craig! come on man...... you need to sort that technical shee-it out brother ;) hahaha!
damnit, I got blue balls now.
Very nice...I need to pick up some of that Syl Glyde...as I'm sure my fittings are dry...
did you clear the IC after blasting it? I would suggest it as it won't stay clean for long.
Yeah, that was in my thoughts.
Which clear brand/type? |
what did you end up doing with the innercooler you bought?
Dan |
Craig,
did you bail on the Blown Six? |
Looks like it - I bought EVERYTHING to install it - I mean every piece of OE Porsche parts required.......and due to the rearward placement of my particular engine it just flat out does not fit/clear the rear structure. Aaack...
Who wants a complete BlowSix 965 IC setup? |
Time to tube frame the rear ala a 935. Your teetering on the edge anyway, right?
I have the BlownSix right here.....it is a damn shame I can't install it.
On the edge is right ;-) |
Hey Craig,
Are you really going to get rid of your 965 IC? I might be interested. David |
I'm pretty certain.
What emission/cold start stuff do you still have? |
Craig,
Interested in your intercooler as well. Is your G50 shortened? Dan |
Craig, too bad about the intercooler. I had been wondering when you were going to install it.
Roughly how far rearwards is your engine versus stock? You said you waxed your intercooler. I did something similar to my intakes after bead blasting them and their appearance has stayed static since last fall and still no water stain marks. So far so good. Edit: Is your breather hose to the oil reservoir kinked or is it OK. It looks like it may be kinked in the first picture. |
I found that just krylon clear works pretty well. I have even done a light dusting of silver from 14-16 inches away then apply clear 5 minutes later and it look like a stock aluminum casting. works really well
| All times are GMT -8. The time now is 06:33 PM. |
