Forced Induction Junkie
WERK I's Avatar
911 SC Cam Timing Specs-Camgrinders Help!
I have been reading Wayne's book and noticed the cam timing specs state the valve lash on #1 and #4 should be set to 0.04" before timing the cams. Is this correct? I always thought the valve lash was at the operating spec of .1mm when timing. Wayne's book states to check Paul Friere's book for timing at the .1mm lash value. That book states cam timing in degrees....got enough tools for now, thank you. Don't want to buy a degree wheel that I'll use once every few years.
Also, what is the best advance to run these cams at in a turbo engine, 1.4mm? The engine is twin-plugged and crankfire.
Thanks in advance.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 07-12-2007, 06:39 AM
Macht Schnell
les_garten's Avatar
Hi Dave,
Curious that nobody has answered you yet? I think you have a decimal off on your valve lash. I did mine .004" which is .1 mm. I also did 1.4mm at overlap for my timing. CAMS ran like a scalded dawg. They were SC's from IA.
Les
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 07-17-2007, 08:54 AM
Macht Schnell
les_garten's Avatar
I mean .04 can't be right, that is almost double your spark plug gap, ehhh? Must be a typo.
Les
Old 07-17-2007, 08:56 AM
