-   -   New B+B headers and overboost (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/358361-new-b-b-headers-overboost.html)
DDDD 07-21-2007 06:32 PM
My shop installed B+B headers and also a zork pipe last week. Since then, my wastegate dump pipe has remained silent. It used to bleed all boost at 1 bar exactly, and now it seems that my wastegate literally is not dumping pressure at all. I saw a boost spike a couple times and after that I kept my foot off the throttle after 1 bar was achieved. I have driven the car several miles and saw no signs that the wastegate worked even once to dump pressure.
I am wondering what could have gone wrong with the install. I thought they just bolted the crossmember pipe up to the wastegate without touching anything. When they tuned the CIS, they removed the intercooler and replaced it.
This seems like the wastegate is simply dead. Not just standard overboost because of new headers and then pressure bleeds, but overboost and no response at all, no release at the dump pipe.
I will probably go to a Tial wastegate. Just want to know if anyone has an opinion on what went wrong before I talk to the shop. Thanks!
mark '87 930 07-21-2007 06:52 PM
Is the tube from the IC to the wastegate connected? They could have not re-installed it (I've made that mistake..oops). There should be two lines coming from your wastegate, one is a vent and goes to atmosphere, the other goes to the IC.
RarlyL8 07-21-2007 07:13 PM
My thoughts exactly, they forgot to reconnect the boost signal to the wastegate. Glad you caught it before hurting your engine!
sand_man 07-21-2007 07:26 PM
I answered in your rennlist post...
DDDD 07-21-2007 08:03 PM
Yeah, I couldn't resist the old double post a question trick! LOL.
