Porsche Junky
Beware....The Bucking....
I came suddenly....silently....
It came as I was having a little tet a tet with a 350Z down an uncrowded rural highway... Done toying, I downshifted and waited for the boost to propel me away from the Z when BAM! The Bucking.... Today was my first chance to really explore the issue...there is definitely a correlation between a suddenly lean condition showing on my WB A/F meter near full boost and....The Bucking....but the car runs great otherwise To be continued......... ![]()
1986 930 RUF equipped |
A fellow Pelacanite
Overboost switch ?
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
Manassas, VA
See my post above
It's called "Intercooler Wiring Modification"
Mark
1991 964 Polar Silver Metallic Turbo Coupe |
Oh, too bad you weren't in that 3.6 conversion you sold to me... you'd have blasted by that Nissan - like when the Enterprise accelerates to mock 10 in Star Trek next Gen... as if you forgot
James 91 Black on Balck 964 C4 (DD) 82 Metallic Red SC 3.6 Varioram (sold) |
Porsche Junky
Hehhehheh....I smoked that Z even with the overboost prob....
![]() Undoubtedly my wastegate is sticking....havn't had time to investigate further...
Wo ist die Rennstrecke?
Re: Beware....The Bucking....
But I did.... |
Porsche Junky
What makes you think it is the wastegate?
C.H. Boost Addiction - honestly, I have it under control 1989 911 Turbo Cabriolet Mods include: Kokeln IC, GHL Headers, Hooligan muffler, Modified K27 7200, BL WUR, LC-1 & XD-16, Bilstein Sports (4), TRG sway bars, Oversize torsion bars, Strut brace |
Did you fix the problem? My car was doing the same thing - bucking violently when coming off of full boost/throttle. Ended up being a torn wastegate diaphragm. It was maintaining the correct boost pressure at WOT, but once I lifted the boost would spike and trip the overboost sensor. A quick way to check: Disconnect the wastegate boost signal line at the intercooler and blow into it. if air passes thru you have a leak.
Steve 85 930 |
It will often leak trough the valve stem even if diaphragm is sound. Wastegate should be "blown" from venting hole on the top...not on the bottom. When "blown" from the top, there is no other way for air to escape but trough the diaphragm.
Thank you for your time, |
