newby please help 930 no boost
i have a 79 930 with 70k miles car has not been used much recently had it out and realized there was no boost, i have checked for a stuck wastegate and it seems fine i have replaced intercooler o ring and still no luck i have also checked the intake side of the turbo the shaft has no play and spins free. any ideas thanks
A fellow Pelacanite
I wonder if your recirc valve is jammed open.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
at the risk of sounding stupid, where is the recirc valve?
2008 BMW 320i 2006 Mercedes ML320 2004 Mercedes ML270 cdi 1998 Porsche Boxter 1988 Porsche 930 Targa (sold) |
That would be under the intercooler.
86' 930 red "Wild @ss Hotrod" Thanks John
Has to be the re-circ valve because the car would spit,sputter, and fart like a champ with an atmospheric boost leak. The re-circ valve creates a boost leak that doesnt violate the fuel metering's calculations. This is assuming it is not the wast gate being stuck open.
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
A fellow Pelacanite
I would block off the exhaust with a rag while an assistant revs up the engine and I would listen at the wastegate dump pipe for any exhaust letting by.
cycling has-been
when I first got my 77, the valve in the waste-gate was cracked and would not seat fully....very low or no boost.
the seating surface was almost completely gone. I found out when I took it to be dyno-ed for some baseline numbers. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
