Lets Play Name that No Start
Well I just finished my rebuild with the following additions:
3.4 P's and C's Sc cams Modded Fuel head K27HFS SSI exhaust Tial 46mm. The first time I started it, it started but rumbled to a stop. It was ignition timing. as I was re-indexing the distributor I knocked the green wire which then disintegrated. I replaced the green wire and now have spark. I then tested the fuel system and couldn't hear the fuel injectors on the left bank, instead I heard a high pressure sound like it was partially clogged. I pulled the fuel distributor and spark plugs, and there was signs of fuel everywhere it should be. I will now either swap out the fuel distributor with my old euro or repair the modded fuel head (please see the other thread about that). The issue is, I have a sneaking suspicion the fuel head is not the issue with no start. wouldn't It still try to fire up even if only one bank is getting fuel? after I replaced the green wire it would crank, but not fire. I figured the plugs were soaked which all six were so I pulled all of them to let the cylinders air out. Anyone have any ideas of what else could be causing this no start issue? |
When I installed the modded head I had to back off the CO significantly, the swap resulted a crazy rich condition to the point of not running. Instead or the 3% I now run at about 0%. It's only one of two things, fuel or spark and you have spark....
Without knowing any more about your engine, you may not be to the HP point where the high-flow head will be manditory (>375whp). If so then one bank may be rich as sly stated, and the other side is dry. That would be a hard engine to start.
Did you pull a plug and check for spark when cranking? |
Also, be sure that the spring-loaded AFR adjustment screw isn't hung-up on your air cleaner assembly; I remember you telling me that you've gone to the style I run (same as RarlyL8). I had to cut a notch in my air cleaner base for the screw. |
Also, keep in mind the ignition dizzy runs counter clockwise in these engines, so be sure your firing order is correct.
I testing the spark on cylinder 1 and it does fire as it should. the left banks plugs were soaking wet with gas compared to the right bank. I think I will just put my stock fuel head on for break in, as I wont be hitting high RPM's, and that will give me a chance to have the modded head tested. Everything has been airing out over night, and I bought some new break in oil as I'm sure the oil in there is full of fuel. I just want to get this baby started before I hit the 1 year mark!
Well I swapped out the fuel distributor with my stock one, once again I am getting fuel and spark, but not even a chance of firing up. The starter is turning the engine, but I'm not even getting as much as a backfire!
I double checked ignition timing, and even turned the dizzy both ways, then tried to crank it. What could I be missing here? I was always worried about the condition of the wires in the harness, but now that I have changed out the green dizzy wire, I am not sure which other wires could be preventing it from firing. Any idea's at all would be greatly appreciated. I am giving myself the weekend to try to figure it out, then its on the tow truck and off to a shop. |
[hiding under my desk] - there's no way that the cams are 180 out...right?
If you need an extra set of plugs...you know where to find me!
Is there anyway to check without removing the chain box covers? If i pull the covers I will need new gaskets since I used sealant. I checked the plugs and they are putting out a spark. |
Well in your opening post you indicated that the car did rumble to a start and then stop when all hell broke loose with that damn green wire! So it looks like it did start and run once...even if briefly. I wonder if your plugs are just shot.
Did you check the spray of the injectors? I usually ascribe to the farmer's tale..."9 times out of 10 it's the fuel", although my last two problems were a)plug wires, and b)completely disintegrated green wire connector. I have tried to check timing on start, just to get an idea of where it's at, but my light won't trigger at that speed and voltage. Possibly someone here knows of a way to do this. I can time it with points but not CDI.
Depending on your schedule, I might be able to steal away for a couple of hours to lend you a hand this weekend. You are welcome to my spare coil, CDI box, and a set of plugs...although it does look like you've got spark.
I will say that I once had a set of plugs gas-foul so badly (in my 930) that they were unusable. |
I emptied out the fuel tank, and put in 5 gallons of fresh premium fuel so i think I am good there, but there was old gas still in the system that could of fouled the plugs. I can also hear the injectors flowing on both sides of the block. If you can make it this weekend, give me a call as it would be greatly appreciated. |
Cool...I'll give a shout later on today (Saturday). One other thing you can check: if you are running a different/new intercooler, be sure that all unused vacuum ports have been properly plugged (intake manifold, BOV housing, etc.). An air leak will also keep your engine from starting and running. The brake booster line off the manifold connected?
At this point I'm thinking it's your spark plugs... |
Update
So Sand_Man came over this evening to try to help me figure this out. This is what we did:
1. Swapped out spark plugs 2. Checked for spark (it was there) 3. Played with ignition timing 4. Even tried moving the dizzy while cranking Still no start. we did notice after it had cranked for awhile and the starter started to slow down b/c the battery was running out of juice, that it made a faint noise like it was almost firing and would shoot out small puffs of smoke, but it was really weak. It was almost like it didn't have enough of something to get full combustion, and it would only happened after cranking for awhile. We also noticed the Tach jumps all over the place and then settles right about when it makes the faint noise. Could this be a grounding issue? I pulled the passenger side valve cover, and while the engine is at TDC I can jiggle the intake rocker. This would tell me the cams aren't 180 off right? Does anyone have any idea's? even if it is just a guess? I would hate to get this far, just to have it towed to a shop, and find out its something obvious. |
Worst case scenario, we were thinking that the cams could be timed 180 degrees out. As a check, if John got the number one cylinder in place for a valve adjustment at Z1 (number one intake and exhaust valves should be "loose"), then the number four cylinder exhaust and intake valves on the opposite side should be tight (on the passenger side)...right? If number four is "loose" at the same time number one is, would that indicate incorrect cam timing?
Also, seeing the tach jump all over the place during starting leads me to believe that it could be ignition related. After several continuous cranks, the engine begins to make a slight sputtering and small puffs of smoke emerge from the tail-pipe, but it just won't catch. I'm confident he's got fuel. |
We also played musical spark plug wires by moving them around different posts on the dizzy - keeping the correct firing order each time. Not sure if it made a difference. The sputtering doesn't happen until several continuous cranks.
Did you try starting the engine with the throttle body completely open?
It sure sounds like a flooding condition, though I don't know why one bank would be wetter than the other. |
I am sure the engine is flooded by now. whats the best way to fix that? I already pulled all the plugs and let it air out over night |
| All times are GMT -8. The time now is 05:21 AM. |
