935TURBO's Avatar
Blow pop off valve...?
Hi everybody....
would that be possible to post some pictures of your pop off valve and location on your 930 with Kokeln or Blown6 IC...and do you have special hose for connection....?
Thanks..
Serge, Gentleman Driver
https://www.facebook.com/photo.php?fbid=10207116408000968&set=gm.1723624077 855805&type=3&theater
Old 11-28-2007, 03:46 PM
I think most aftermarket I/C's use the 965 rubber elbow from the throttle body, it has a fitting on the top for the 965 recirculation valve.With my Kokeln, the pop off valve casting is removed.
If the 965 rubber elbow is what you're after, there's pictures
930 Pop off Valve
And I found this quite useful:
http://members.rennlist.org/magisterc/kokeln.html
I thought you already had a Kokeln? Was yours installed differently?
'77 S with '78 930 power and a few other things.
Old 11-28-2007, 04:56 PM
935TURBO's Avatar
Oh thanks Spuggy....I got one with my KOKELN with the same configuration as on the thread....but as I'm selling the IC, I just wanted to know if I have to give other things with the IC.....
As my actual configuration is as on the thread you linked....does the "elbow" from a 965 stok....?...
Old 11-29-2007, 12:24 AM
Up to you, but it'll be more attractive to the buyer if you're offering it complete with everything they need to bolt it up, I'd guess
I believe that Kokeln sell the fitting kit separately, so you could either keep it & discount by the cost of the kit, or buy a fitting kit for yourself/the new owner of the Kokeln.
Sorry old man, don't understand your banter... (Monty Python sketch).
If you're asking if the elbow is a factory 965 piece, it either is, or it's so close you really can't tell by looking at it while it's on the car. I think this piece isn't too bad, it's the other 965 pipes that are extraordinarily expensive for no apparent reason...
One of my wrenches thinks the Kokeln alloy extender for the intake pipe from that elbow is nicer than the factory 965 rubber pipe (happened to be chatting to him whilst he re-fitted a 965 I/C the other day).
Old 11-29-2007, 04:37 AM
