Me like track days
Craig 930 RS's Avatar
Question HUBS "early or late" ?
Working on ordering a set of Kodiak wheels. Jeff needs to know if I have 'early or late' hubs - a '21 mm difference'. Heck if I know - and he does not -
What do I have from the factory?
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 12-09-2007, 09:02 AM
Rory Mckenna's Avatar
What year is yours 930?
Old 12-09-2007, 09:10 AM
Jeff Alton's Avatar
The car is an 82, and my part catalogue on lists the 78/79 and the 84-89. Pet also does not seem to show the years....
Craig, do you by chance know the offset or backspace of your current front Kinesis wheels?
Cheers
www.turn3autosport.com
Old 12-09-2007, 09:15 AM
sudo apt-get purge 930
equality72521's Avatar
Front is 930-341-065-00 up to 1980 and 930-341-065-01 from 1981 according to our host. Rear is 930-331-065-03 which appears to be them same up to 1986. I would say you have "late" hubs by the numbers.
--clutch-monkey
Old 12-09-2007, 09:29 AM
Me like track days
I can find nothing in the records indicating the backspacing of the wheels...
Ah - this will help - a picture:
Old 12-09-2007, 10:15 AM
A fellow Pelacanite
NathanUK's Avatar
I would say you have late. They look like mine. As stated I am sure that '81 on had the later hubs.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 12-09-2007, 01:38 PM
7.0:1 > 11.3:1 > 7.0:1
Is it safe to assume there are only the two different hub offsets from 78-89?
Old 12-09-2007, 03:07 PM
Jeff Alton's Avatar
Yes, the later one places the wheel mounting surface in the same spot as the early one with the spacer on it.
Cheers
Old 12-09-2007, 03:15 PM
Me like track days
Cool. So Jeff - I have the late then?
(Thinking of a Kodiak wheel order thru Jeff)
Old 12-09-2007, 03:20 PM
David's Avatar
Looks like the late style to me. Either way you should get wheels for the later hubs in case you convert to big reds. AFAIK, all 78-on 930's should have the same front wheel offset, the only difference is whether or not it has the 78-79 model's 21mm spacer. I'm not sure what the 76-77 930's have.
Old 12-10-2007, 04:23 AM
9dreizig's Avatar
Send a message via AIM to 9dreizig
Jeff is right, I have both, the early ones ( I have an 80 are two piece), later ones are one piece like you have..
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 12-10-2007, 06:19 AM
