cl8ton's Avatar
Need Zork
Here is the Zork in action
Calling Brian for the Zork as soon as corner rebuild is done.
Rod...
2010 - 997 PDK, Black on Black, Daily driver.
1987 - 930 Grand Prix White, Not looking for crazy HP, just harmony!
Old 12-06-2007, 11:04 PM
sudo apt-get purge 930
equality72521's Avatar
Why not send him PM?
http://forums.pelicanparts.com/members/1862.html
--clutch-monkey
Old 12-07-2007, 05:01 AM
Crotchety Old Bastard
RarlyL8's Avatar
Appreciate it!
The PM box is perpetually full. Phone or e-mail works best.
I just got back from the Porsche homeworld (CA) this evening, where you at? 4600 miles and 2 time zone changes in a weekend has me pretty whacked.
Old 12-09-2007, 10:09 PM
cl8ton's Avatar
RarlyL8, will be calling you before the end of the year to get a Zork ordered!
Cant have allot of car part boxes showing up at once (wife keeps track)
Weird thing, I accidentally started this thread I was replying on a previous Zork thread and guess I fat fingered the mouse click!
Rod...
Old 12-10-2007, 07:02 AM
930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
I was setting the timing on my car in the dark and i was snapping the throttle and watching flames shoot out like a kid playing with matches!!!! Haaaaa , good stuff
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 12-10-2007, 06:06 PM
RarlyL8's Avatar
This one was made up for use with a V-Band clamp and is on it's way to Australia.
Old 12-10-2007, 07:56 PM
cl8ton's Avatar
h20cooled7
You mean like the poster I found and posted below
You big tease, my right leg is starting to jerk!
RarlyL8
That is SaaaaWeeeeet! Almost have my corners finished hang onto a Zork and WG pipe for me...We be talking!
One Q though, I still have the LDZ & stock WG, your pipes work on this and when I goto the K27 HF & Tial WG ??
Rod...
Old 12-10-2007, 08:09 PM
RarlyL8's Avatar
The Zorks will fit all KKK/T4 turbos and the waste gate dumps fit any 4-bolt 46mm W/G.
The 934 waste gate dump is designed specificly for the J-pipe heat exchangers.
Old 12-10-2007, 08:32 PM
h20cooled7's Avatar
yeah I thought I was seeing stuff but I cracked the throttle a few more times and the gates of hell opened. Awesome!!!!!!!!!! If you are a 935 junkie get one , they are a blast
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 12-11-2007, 06:47 PM
cl8ton's Avatar
Getting close to Zork time!
My car rides pretty low and with a Zork exiting under the valence and taking some
measurements, I am afraid I will smash it.
I have a question to all…
I may need to angle the Zork upwards aft of the valence by a few degrees because of a steep
driveway plus I live in the Speed Bump Capital of the World, anyone ever do this? Any pictures? Or don’t worry about it?
Rod...
Old 12-24-2007, 02:18 PM
RarlyL8's Avatar
I can back cut the zork outlet which will help some. Mine are designed to be about 3/8" from the valance.
Old 12-24-2007, 07:21 PM
cl8ton's Avatar
Thanks Brian, calling you this Friday to order!
Guess I will blaze this path, an upwards-angular Zork! Just hope it doesn’t look too Blingy or TypeR’ish when finished!
Will post a pic when finished!
Rod...
Old 12-25-2007, 12:16 PM
WydRyd's Avatar
Yup, that's mine and I LOVE it! It sounds nasty as hell. Anyone who comes up next to me on the road is just too scared to even try
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 12-25-2007, 02:52 PM
one thing to remember guys is that The triple k turbos are t-3 and not t-4 in size there is a big difference on the hot side but should not effect zork angle or postion much
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 12-26-2007, 05:07 AM
cl8ton's Avatar
Ordered my Zork from RarlyL8!
Was wondering though, if I angle it upwards and water enters the outlet that may puddle water up to the turbine blades! That cannot be a good thing…
Maybe I should drill a small hole at the lowest point in the Zork to bleed off any water that enters ???
Ben (mb911) studying the angles on the rear of my 930 and trying to find one that I could match the Zork too, I think the angle of the Tea-Cup spoiler, the area running from right above the Turbo badge to the aft tip of the spoiler is the angle I want. About 45 deg, do you or anyone think this would impede exhaust flow from the turbo to the point of “Not worth it / Damaging”?
Rod...
Old 12-30-2007, 05:33 PM
cl8ton's Avatar
Got a new cell phone today!
It’s shiny with a brushed stainless steel look to it and built with impeccable quality!
Salesperson was top notch and very knowledgeable about the product he sells, will definitely buy from him again
It’s amazing how they can cram so much performance into such a small package these days!
Haven’t heard yet, but was told the ring tone decibel level is….well…ample
Included a few pics!
Rod...
Old 01-04-2008, 05:12 PM
Macht Schnell
les_garten's Avatar
Gorgeous!! Nice welding. I'll bet it whistles nice.
Les
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 01-04-2008, 05:20 PM
cl8ton's Avatar
Hay Les...Thanks!
Man I am excited to get this installed
Can't wait to give it the Starbuck test!
Rod...
Old 01-04-2008, 06:00 PM
Sweet Music...
http://www.youtube.com/watch?v=QCXqFqIEocM&feature=related
Old 01-05-2008, 05:14 AM
