-   -   Need some feedback on a new gauge I am working on (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/389346-need-some-feedback-new-gauge-i-am-working.html)
89turbocabmike 01-28-2008 10:53 AM
plx units are quite good and flexible, very good base for your project. I've got quite a few customers using their system with great results:)
les_garten 01-28-2008 12:23 PM
Originally Posted by Jeff Alton (Post 3732038)
The turbo spins from flow, not pressure. Now I agree that it creates a restriction that can cause back pressure in the exhaust between the turbo and the exhaust valve. I am just curious how much pressure are we talking about here?
I thought David (125 shifter) was monitoring both banks on his efi single turbo as he seemed to know when one side was running lean.
Turbo semantics aside, I had not heard that an o2 sensor would not work in a pressurized area. Not saying it is not true, but I am curious as to why and where I can read up on the theory.
Cheers
Hi,
I think he picked up on the Lean Bank by Temperature differences from left to right. The difference was a retarded cam. The other reason not to put it before the turbo is Heat Sink skewing the readings.
Les
NathanUK 01-28-2008 02:06 PM
Wish I knew more, sorry I don't.
dean 01-29-2008 05:35 AM
Cheers
Pre turbo, there can be as much as 2x the boost pressure.
I think you can read about the O2 placement on the Innovate site.
Jeff Alton 01-29-2008 06:44 AM
Thanks, reading up!
Cheers
les_garten 01-29-2008 07:54 AM
Originally Posted by Jeff Alton (Post 3734864)
Thanks, reading up!
Cheers
Hi,
It's pretty simple equaton here. The sensor should be 8" from the turbo and downstream. You probaly will find it hard to get 8" from the turbo. I put mine between the muffler body and the Turbo flange after screwing up twice and putting it in the coillector ahead of the Turbo. If you put it pre turbo and a professional tells you the Heat soak will make it read wrong, it will worry you till you move it. That is, if you are tuning with it. It read about 1 point rich before the collector as opposed to after it for me. In another words, the car was leaner than my AFR was telling me.
Les
