-   -   turbo alignment (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/390717-turbo-alignment.html)
Alan L 02-02-2008 08:04 PM
turbo alignment
Is the turbo housing alignment fixed, or can it rotate on the clamp.
I am trying to get the intercooler to sit square on the inlet neck. The option at the moment seems to be to rotate the inlet pipe fractionally. Can this be done?
Alan
DSPTurtle 02-02-2008 08:39 PM
You have to spin the inlet pipe (to the intercooler) around a little bit to get the intercooler to sit flush. No big deal at all. Just grab the pipe and twist it. It is only held in by compression when the intercooled is bolted down. People will tell you to be wary of ripping the o-rings, but there should be enough oil in the tract that all you have to do is wipe some of it on the orange o-rings. In all seriousness, just grab the pipe and rotate it until the intercooler is sitting flush. All should be fine.
NathanUK 02-03-2008 01:50 AM
You can rotate the turbo housing if you need too. Just be careful and take your time.
Alan L 02-03-2008 10:18 AM
[QUOTE=DSPTurtle;3744867]You have to spin the inlet pipe (to the intercooler) around a little bit to get the intercooler to sit flush. ]
Done that - but the angle is still not right. I can trace it back to the way the turbo body bolts to the headers. But if the housing can rotate slightly around the clamp, then I can fix it.
Nathan - is there anything I should be wary of? I am assuming these are just flush faces clamped together ? I did try giving them a nudge, but would not budge. I guess the turbine spindles lock the whole thing in place, so you don't have much leeway in trying to manoevre it?
Alan
NathanUK 02-03-2008 10:39 AM
The centre sections hoolds the turbines. The cold housing should be removable. Maybe you will have to pull it off before you can simply rotate it. Do it carefully so you don't damage the turbine.
Alan L 02-03-2008 11:03 AM
I was trying to rotate it from the wrong bit - the C clamp cast iron section. Not sure how that all fixes together. Loosened the bolts around the Aluminium housing and moved as smoothly as. Problem solved.
Alan
78P930 02-03-2008 09:19 PM
How much torque do the turbo housing bolts need?
Alan L 02-04-2008 10:34 AM
I don't know - someoene else may - but typically those bolts would need about 8-10lb. Not too critical I suspect, as there is a strap between bolts doing the work - rather than the bolt heads themselves.
Alan
JFairman 02-06-2008 11:51 AM
They don't go on very tight. Just a little more than snug.
Don't overtighten them.
