What are the benefits of v-band?
I have seen Precision and Garrett turbine housings advertised with v-band outlets. What are the benefits of v-band? If someone has a good link explaining the benefits, I'd appreciate it as I haven't found anything yet. Thanks!
Andy - 1987 911 Carrera Coupe |
V-bands are a quick effective means to make the attachment in this location. However the turbocharger must be mounted off the turbine housing and a v-band can not be used for mounting it (on a street application), therefore you would need to bracket the turbine inlet flange.
Thanks! I guess it'll all make more sense shortly as I just purchased the Precision SC6162SPR from TD Autowerkes.
You can rotate the flange in continuous fashion until the position is right. Also, it can be undone quickly.
Thank you for your time, |
I wish I could get Tial's V-Band inlet and outlet housing, It is soooo cool and flows even more than a normal housing.
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
