Engine flooding after running for a few minutes?
I started my 88' 911 turbo the other day, and after running for a few minutes it started missing then died. It wouldn't start and I could smell fuel. I pulled the plugs and they were soaked. The car is stock except for B&B exhaust. Any suggestions?
Old 02-25-2008, 07:54 PM
rsrmike's Avatar
How long has it been since you last started it?
Did it spit out black smoke before it died?
How long did it miss before it actually quit running?
How long did you spin the starter over before you smelled fuel?
Have you checked for spark?
If you turn on the ignition, do you here a quiet, high pitched squeel in the left rear corner of the engine compartment?
If not, try wiggling the plug on the bottom of the CD ignition unit and trying again... just a few quick thoughts
Old 02-26-2008, 04:37 PM
I have not tried to start it since this happen. Before it died it spit out flames. It missed about 20 seconds. When I turn the key on now I can here the injectors running. Could the fuel dist. be shot? It does have spark.
Old 02-27-2008, 09:30 AM
A fellow Pelacanite
NathanUK's Avatar
That's likely to be the CDI you can hear.
Did you have any fuel being dumped out of the WUR? It has a hose to the air cleaner assy for safety if the WUR blows its diaphragm. Brian Leask can rebuild the WUR for you if this is the problem.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 02-28-2008, 12:56 PM
