After the next project
x98boardwell's Avatar
Fuse Relays. How to remove and where to find them?
Hello,
I am looking to pull my fuse relays which will allow me to turn over the motor and not start.
Can anyone tell me (photo's would be nice) where they are located and which ones need to be pulled... I think it is 2 of them.
Thanks in advance,
Bryan
Old 02-29-2008, 10:28 AM
A fellow Pelacanite
NathanUK's Avatar
You could just disconnect the overboost switch. Not the answer to your question but...
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 03-01-2008, 01:07 AM
Cowtown10's Avatar
Inside front drivers side fender. There should be a diagram on the inside cover with whats what
http://www.pelicanparts.com/PartsLookup/HTML/911_USA_84_86_KATALOG/902-00-Frame3.htm
Q
1991 RRC
1995 993 C2
2002 996TT
1984 930 Turbo (gone and missed)
Old 03-01-2008, 08:11 AM
Engine Location
Is there one in the engine compartment as well.
Since there is two fuel pumps, I would think there would be two relays?
Thank you for the help so far.
Bryan
Old 03-01-2008, 08:41 AM
Cowtown10's Avatar
Hey Bryan,
I just replaced both my fuel relays...they are side by side and both should be red...the other fuse relays are black.
I am just figuring things out as I go so hope that helps
Q
1991 RRC
1995 993 C2
2002 996TT
Old 03-01-2008, 09:07 AM
resident samsquamch
sand_man's Avatar
Agreed with what Nathan said...disconecting the over boost sensor should keep things from starting, provided the wiring hasn't been "jimmy'd" with by a previous owner.
In my car, the two relays closest to the windshield are the fuel pump relays.
-jeff
Old 03-01-2008, 11:27 AM
Cowtown
Everybody, thank you so much for the help. I removed the Red Relays closest to the windshield and it stopped the fuel pumps from coming on. Great.
I did not want to just remove the overboost switch as I would have been dumping fuel in the motor while I was trying to prime the new turbo.
It took almost 30 seconds for oil to come out of the bottom of the turbo as I had replaced 3 oil lines, drained the motor twice in 30 days and it ended up taking 12 quarts to fill.
Once again, I appreciate all of your help. This forum has been a great resource for me.
Bryan
Old 03-01-2008, 02:32 PM
Cowtown10's Avatar
Quick question
I am having fueling troubles...after checking the relays, and fuel pumps is the mass air sensor something to check or the overboost sensor...I am not sure what the overboost is? or does?
Q
1991 RRC
1995 993 C2
2002 996TT
Old 03-01-2008, 03:29 PM
Sorry
Cannot answer that question due to lack of knowledge. Hopefully, someone else can chime in here.
Otherwise, search the forum for your answer and there most likely have been threads on this subject already. Good luck.
Bryan
Old 03-01-2008, 04:16 PM
Cymru am Byth
carmad's Avatar
Cowtown,
The overboost sensor does exactly what it says, if boost from the turbo gets to high it will cut power to the fuel pumps. helps to stop the engine from getting damaged from high boost levels.
If you have ever had it cut in, you will almost shoot through the windshield if you dont have your seatbelt on.
It is a small sensor located under the intercooler, with a couple of wires coming from it. Some people short it out to stop the sensor working, not a good thing to do, you would risk damaging your engine.
1986 930 (Gone but not forgotten)
1995 993 (Should Never Have Sold it)
2007 BMW 328Xi Sport Wagon
2005 Lexus GX470 Offroader
Julian Williams
Old 03-01-2008, 05:16 PM
Cowtown10's Avatar
Ha too simple...but unfortunately not my issue then. My car dies either from a minute or two on idle or wont get fuel to fire up....hmmmm, could it be mass air sensor?
Q
1991 RRC
1995 993 C2
2002 996TT
Old 03-01-2008, 09:53 PM
Non User
infraredcalvin's Avatar
This seems to be the right place to post since we're on the subject I have a 76 turbo, pretty much stock, but does anyone know the difference between the black relays and the red fuel relays? The PO (and I still haven't changed it) had the black relays installed for the fuel pumps. I know the part numbers are different, but are they similar enough that they wouldn't cause any issues?
I'm trying to dial in my car, every once in a while (only in low rpms) it feels like I get an air bubble in the fuel delivery and my car will stumble for a split second, the fuel pumps have been rebuilt, I'm wondering if it might have something to do with the relays...
Any comments?
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
‘71 914-6 GT 3.4L twin plug track car
'75 914 GT clone project
'71 914 track car, fresh 2165 FAT motor (for sale soon)
Old 03-09-2008, 11:18 AM
A fellow Pelacanite
NathanUK's Avatar
Could be. The red relays stay closed slightly longer than the black ones when power gets cut to the coils inside IIRC.
Old 03-09-2008, 01:41 PM
