-   -   how to tqke out the clock? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/398617-how-tqke-out-clock.html)
mdurbahn 03-16-2008 01:52 PM
How do you take the factory clock out?
e p slick 03-16-2008 01:57 PM
clock
Clock is held in place by thick rubber surround O ring like rubber gasket thing. Merely grip clock bezel/edges with fingers and wriggle it loose and out. All other gauges in you 79 are secured in similar fashion. EPS - Tucson
wcc 03-16-2008 02:05 PM
I used a stiff putty knife to get under it and slowly and gently worked around the bottom of it and it eventually loosened up enough to pull it out. Good Luck.
Hayabusa 03-16-2008 02:14 PM
You might want to coat that edge with a little tape, and also tape around the area, so that in case you slip it will protect against an unsightly scratch.
mdurbahn 03-16-2008 02:46 PM
Got it out, thanks. Now to route the vaccum like up there.
mdurbahn 03-16-2008 04:01 PM
Now I am having trouble running this line, there seems to be no openings between the gauge cluster and underneath the dash, is there some trick to this too?
e p slick 03-16-2008 04:30 PM
line
Cutting torch or big auger.http://forums.pelicanparts.com/uploa...1205710209.jpg
